Yep, there has been a lot of people getting the finned aluminum rear cover for an 08 and it will fit all 10.5 and 10.25 axles.Okay here's a real question for you...will a diff cover off of a 10.5" fit on a 10.25" axle?
yesOkay here's a real question for you...will a diff cover off of a 10.5" fit on a 10.25" axle?
Well lets see the pics.Will try to get some good burnout pics when done, I still have the old scab tires on so that will be fun,can't wait. Locker is in cover on tonight,then smoke.
Ditto Damn it!Well lets see the pics.
:rockwoot: :redspotdance: :rockwoot:i hope it's more than pics....video of tires blowing will be much more exciting
Does this mean that you can use a 10.5" gearset from a SD in an OBS 10.25 rear end?Ring gear size and inner pinion bearing size are the differences between the 10.5" and 10.25"
The inner pinion bearing is taller to make up for the 0.25" difference in ring gear diameter. Other than that, the housing is the same as are the rest of the internals.
RTV and go.......but you probably already did that by now.Speaking of diff covers, I just received mine from Bob at PowerStrokeShop, nice unit.
But I do have questionabout installing this thing.
It has a groove around the inside flange. Is this for an o-ring, or just glue it up with some RTV?
I'll be picking up some polished 12 point bolts for the install. May even run a string of saftey wire around it for good luck.
MrBill.
