So, my last brake job was 90,000 miles ago and that was just rotor turn and pads. I mostly highway drive so generally not a lot of braking like city driving. At 158,000 miles on my calipers I ended up with dragging front driver side brake. I'm guessing the hub got so hot it cooked the dust seal on the end of the axle. See pic. I'm wondering how important this seal really is if I'm mostly on pavement and occasionally drive through some sand and dirt. Also curious what the dust seal and oil seal replacement procedure involves and should I replace the oil seal at the same time. I'm thinking it might be good to do both sides while I'm replacing brake components. Fyi; the wet on the seal is from me attempting to clean it to identify and then lubing it thinking I might push it back in. Turns out the seal is split into two pieces with the inner ring still on the axle. I have no idea how long this seal has been dangling. Just assuming the brake heat cooked it in two.
Thanks in advance for sharing your experience.
