1 - 2 of 2 Posts
a friend of mine is looking at a 06 Harley and is interested in all of the info he can find before buying it
IFTWW3IP85EC52630 Thankx....
OASIS RESULT: 1FTWW31P85EC52630
USA: EN-US
05-JULY-2011 / 19:51:52 / FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 F-SERIES BODY STYLE: F-350 CREW CAB 4X4 ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT AXLE CODE: 3L ENGINE CALIBRATION
PAINT COLOR: EBONY WB C/C-W/B RADIO: AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT: 11,400 LB. GVW
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 8X20" FORGED POLISH ALUM WHEEL FRONT TIRE: 275/65R 20E A/T BSW TIRE
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ACCURATE REPAIR NOTIFICATIONS
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 25-APRIL-2005 BUILD DATE: 24-FEBRUARY-2005 SALE MILEAGE: 00011
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
Standard Claims List For Model Year 2005
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 14 1H03 030008 5C3Z 9F452 AA D36 42 31317
AWS Claim Key: 4811947 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: B4091 - * Name: KEYSTONE FORD SALES LIMITED Ph: 204-6619555 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:31-MAY-2006 Doc #:030555A
Cust Comments: INSPECT FOR NO POWER FROM A STOP (REPAIR ORDER CLOSED OUT FOR MONTH END PURPOSES PART ORDERED BY 440)
Tech Comments: 50401 PERF TESTS P0404 TEST EGR CIRCUITS PASS CYCLE EGR STICKING REPLACE EGR RETEST OK
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 18 2E03 030402 4C3Z 9E527 AA D50 42 41954
AWS Claim Key: 6403226 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:11-OCT-2006 Doc #:04824001
Cust Comments: ENGINE RUNS ROUGH COLD. BLOWS BLACK SMOKE AND LOOSES POWER. CUSTOME
Tech Comments: REPLACE 4 INJECTORS AND UPDATE PCM,FICM,TCM. RETEST COLD. RUNNS GOOD.
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 18 1H03 030008 5C3Z 9F452 AA D36 42 41954
AWS Claim Key: 6620033 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:11-OCT-2006 Doc #:04824002
Cust Comments: NO PWER WHEN DRIVING AFTER ONE DAY OF DRIVING.
Tech Comments: EGR VALVE IS STUCK.REPLACE E.G.R VALVE. O.K. TRY FOR A COUPLE OF DAYS.
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 19 * * * * * * * 43665
AWS Claim Key: 6644892 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:08-NOV-2006 Doc #:04897103
Cust Comments: 05B32 DEGAS BOTTLE DECAL
Tech Comments: INSTALL STICKER AND ADJ FLUID LEVEL
AWS Claim Key: 6644891 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:08-NOV-2006 Doc #:04897102
Cust Comments: 05B35 PCM RECAL
Tech Comments: PERFORN RECAL AS PER INSTUCTIONS
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 20 1H03 030804 4C3Z 9P456 AF L87 42 46150
AWS Claim Key: 6695166 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:04-DEC-2006 Doc #:04950301
Cust Comments: ANTIFREEZE LEAK ENGINE LOSING A/FREEZE
Tech Comments: PRESSURE TEST COOLING SYSTEM FOUND EGR COOLER LEAKING, R&R BELT HAD COOLANT ON IT WHEN THE E.G.R. COOLER BLEW UP ON THIS UNIT. THE BELTWOULDN'T WORK VERY GOOD WHEN IN IS CONTAMINATED.
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 25 2E01 03XXXX 4C3Z 9B246 A D02 42 55989
AWS Claim Key: 7900551 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:14-MAY-2007 Doc #:05252301
Cust Comments: DRIVEABILITY TRUCK WOULD NOT START AT FUEL STATION TOWED IN
Tech Comments: DIAG NO START,VEHICLE STARTS.ROADTESTTO GET HOT,LET SIT AN
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 28 2E03 030402 4C3Z 9E527 AA D42 42 58246
AWS Claim Key: 8286568 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: B8802 - * Name: DINGWALL FORD SALES LTD Ph: 807-4686443 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:16-JUL-2007 Doc #:22235301
Cust Comments: CUSTOMER REPORTS THAT THE VEHICLE RUNS ROUGH AND MISSES BADLY ON ACCELERATION,INSPECT AND REPORT.
Tech Comments: INSPECTED AND VERIFIED CUSTOMERS CONCERN,VEHICLE IS MISSING BADLY,PERFORMED SELF TEST,RETRIEVED P0263/P0269/P0255 PERFORMED POWER BALANCE TEST AND CONFIRMED CYLINDERS 1,3 AND 5 DROPPING OUT,AND INJECTOR REPLACEMENT IS REQUIRED, REMOVED AND REPLACED THE INJECTORS,AND RETESTED IDENTIFIED INJECTOR 7 DROPPING OUT AND REPLACEMENT IS REQUIRED,REPLACED INJECTOR 7 AND RETESTED OPERATION,OK,
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 46 2E03 0304XX 5C3Z 9C968 CA D13 42 88113
AWS Claim Key: 10753247 Trx Code: E72 Labor Hrs: 1.6
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2009 Doc #:06419902
Cust Comments: DRIVEABILITY CUST REPORTS VEHICLE RUNS ROUGH
Tech Comments: RETRIEVED CODES P2284,P2287,P2291.FOUND BIAS ICPSENSOR AND
1FTWW31P85EC52630 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 24-FEB-2005 25-APR-2005 4B4079 CAN 46 1A02 030102 4C3Z 6051 EB L87 42 88113
AWS Claim Key: 10764796 Trx Code: E72 Labor Hrs: 22.9
Dlr Cd-Sub Cd: B4079 - * Name: WILF'S ELIE FORD SALES LTD. Ph: 204-3532481 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2009 Doc #:06419901
Cust Comments: HEATING/COOLING SYSTEM CUST REPORTS LOOSING A/F WHITE SMOKE OUT TAIL PIPE
Tech Comments: FOUND COOLANTLOW AND WHITESMOKE AND COOLANT OUT THE EXHAUST. FOLLOWED TSB 081103 STEP ONE RESULTS BAD RESOVOIR CAP. REPLACED CAP. STEP TWO RESULTS EGR COOLER DOES NOT HOLD. STEP 3 RESULTS REMOVED EGR COOLER AND FOUND LEAKING. STEP 4 RESULTS INDICATED VACUUM REMOVED AND REPLACED OIL COOLER. INSTALLED NEW EGR COOLER ASSEMBLED ENGINE TOPPED UP FLUIDS. ROAD TESTED COMPLETE. STEP 5 DURING ROAD TEST NO
1 - 2 of 2 Posts
