1 - 3 of 3 Posts
Replaced (all of oil system) high pressure and low pressure oil pumps and oil filter pump etc. truck ran for 20-25 miles and died. Any thoughts (will not start):eek:
09 6.4
check ipr valve, oil filter pump? never heard of that one LOL! if you have a scanner monitor your ICP actual pressure versus the desired ICP pressure..should be around 500-600 psi. also monitor the IPR %...this should read a low percentage when cranking...maybe 15%.
1 - 3 of 3 Posts
