1 - 4 of 4 Posts
C&C Customs
i just bought an 06 set of frnt and rear axles and all the suspension brackets and parts. so how hard is this swap!? my main worry is aligning the brackets so the axles are square is it all bolt on? i am ready to do the swap once i get some guidance
i figured Caryt could help
I did it in an OBS, and other than needing to fab a trac bar mount, we had everything done in a day. Everything was square, and only out 1/32" left to right.
I would think that your frame should be about the same, so find an 05+ and take measurements.
good luck
Done it. 85% bolt up. You will have to drill a few holes for the radius arm mounts, coil buckets and track bar, but most are already there so alignment is not a problem. I am using the stock track bar mount too.
Easy..if you need help or parts needed..PM me.
Cary
1 - 4 of 4 Posts
