1 - 9 of 9 Posts
Really???
2005 Ford F-350, DRW, 6.0L, Supercab, Lariat, FX4, 8’ bed, 55,300 Miles, Compound-Turbos, Original Owner, Clean Title in hand
Leather interior, Heated seats, adjustable pedals, power rear window, Kenwood speakers and a 4-channel amp, New Rancho shocks, New alternators, New front tires. Air tank mounted on frame rail, air compressor mounted above spare tire. Tool box included.
Truck has the following add-ons:
B&W lighted “cab protector”
JadSolutions “FireStars” under door lights
AMP Research “PowerSteps”
Isspro above mirror gauges –pyro,boost, and trans temp.
*Stage 4 “Max Power” 240cc Injectors
*Fire Ring Kit
*Coolant Circulation Line Kit
*“High Power” Compound Turbos
*Low Pressure Oil Pump Gears
*Stage 2 Fuel System
*Stage 1 Camshaft
*Competition Pistons/0.20 Over Bore
*Competition Piston Ring Set
*Coated Main Bearings
*Coated Rod Bearings
*Forged Connection Rod set
*Billet Flex-plate SFI
*FS2500 Bypass Oil Filter Kit
*Stage 1 Valvetrain Upgrade
*H-11 Head stud Kit
*H-11 Main stud Kit
*Remote Oil Cooler Kit
AFE Stage 2 XP Air Intake System
Spearco Intercooler
4” MBRP Dual Exhaust System- Stainless -Turbo Back
Suncoast Transmission with Competition Upgrade, Triple Disc Torque Converter , Mag-Hytec Trans Pan, and Billet Shafts
*Bought from “Elite Diesel Engineering”
**All engine parts installed at 51,444 miles by “Elite Diesel Engineering”
**Transmission installed at 51,320 miles
**Other parts included but not installed are: B&W Turnover Ball Gooseneck Hitch, Firestone Ride-rite Airbag Kit, Black Cloud Diesel Stack kit with 6” Mitre Stack
**Will also include 24 quarts of Mercon SP Transmission Fluid, 3-Oil Filters, 1-Transmission filter, 3-Fuel Filters, 2-FS2500 oil filters, and a New Black Grill
Asking $32,500 obo
Bird is the Word
how did it do towing 10K+ loads?
Really???
Discussion Starter · #5 ·
I only towed 7-8k with it. It did well as long as you give the wastegate 2 turns to clear up the smoke. Never towed 10+ so I can't say. I chose the combination I run as opposed to stage 8 injectors because I still wanted some tow ability.
1 - 9 of 9 Posts
