1 - 2 of 2 Posts
2005 Ford F450 Lariat crew cab 4x4, 6.0L Powerstroke diesel, auto trans, 4.88 gear ratio, Lariat leather interior with all the options, Link Manufacturing full air ride self leveling rear suspension with kneeling option, Toyo 265/70R19.5 tires w/ spare, dual fuel tanks w/ 72 gallon capacity (new 40 gallon Titan main / 32 gallon Transfer Flow under bed aux) and Transfer Flow Trax II auto control module, dual alternators, Pioneer stereo, newer style step tailgate w/ back up camera, in-bed hitch rails with gooseneck and 5th wheel heads, 2.5” receiver hitch, spray in bed liner. New engine 30k miles ago using a Ford short block, ARP H11 head studs (the $1400 studs not the $500 studs), commonized cylinder heads rebuilt with stellite exhaust seats, RCD valve springs, Smith Bros 6.4 pushrods, new lifters, new injectors, new front engine cover and LP oil pump, new HP oil pump, new block heater, and all new engine sensors. The truck is fully “Bullet Proofed” with every durability upgrade including SPD EGR cooler delete, SPD up-pipes, new Garrett turbo, BD exhaust manifolds, BPD HD external oil cooler system, BPD external oil filter, BPD 6 phase 58V FICM, BPD billet water pump, Mishimoto aluminum radiator, external coolant filter, ELC coolant system conversion, S&B cold air intake, MBRP 4” stainless exhaust, Dieselsite charge pipe boots and clamps, SCT Livewire, Autometer gauges, etc. Boss plow frame was installed two years ago and truck has only been used to plow my driveway several times, no commercial plowing. Chassis currently has 302k miles. I have gone thru the entire truck using the best parts available and spent well over $30k……….$20k just within the last two years. Things changed and I don’t need a truck this big for daily use anymore, I want something smaller. The truck has been professionally built, repaired, and maintained with an open checkbook at the area’s best Ford Powerstroke diesel specialty shop OSP Diesel. Asking $19,500 OBO……call for more info. Truck is located in Warwick RI. I'll be traveling from RI to FL along RT 95 in Feb and also in March. Delivery possible. Lots more pictures available
1 - 2 of 2 Posts
