1 - 7 of 7 Posts
Has any one swapped in a 05cr and 48re into a 02 f250? I need help with the wireing and any other useful hints to safe time on the conversion.
I did but I cheated and used painless wire harness. If you dont want to do it yourself you can send your harness to destroked and they will modify it for you. If you do end up doing it yourself your going to need lots of patience and good wire diagrams for both dodge and ford trucks
What did you do for the 48RE to get it working?
I'm running a PCS controller, a painless harness will not controll the trans
Fixing Broken Stuff
Fixing Broken Stuff
How hard was it to get it working? The reason I'm asking is because I have a 24v and 5r110, and I'd like to use the two in a conversion. I have seen some posts that were not very positive on using the 5r110. Any advise? Thanks
1 - 7 of 7 Posts
