1 - 5 of 5 Posts
Found out that the main metal support piece is not the same as on the earlier models, looks like it has 2 radio support brackets welded to the top tube. 98% the same but small differences, EATC should be fun as the harnesses are completely different.
Diesel Huffer
its completely differnt from 99-04 models, did it in my 03 had to have metal bracing, all plastics for the dash etc plus the ducting is differnt to.
EATC heater housing is slightly different with an air tube and an ATC controller in place of the manual one. Another thing of note is that the heater core inlet and outlet sizes changed on the 05s, had to use the 02 heater core in the 05 EATC heater box.
Still working on the wiring for the EATC and the cluster. Radio controls and EATC controls work from the steering wheel. 4x4 switch on the 05-07 has a different resistance value that the earlier switches, had to use the older switch. Older style manual heater controls will work with the new dash bezel.
All done now
Looks good.
1 - 5 of 5 Posts
