1 - 4 of 4 Posts
Which is best lift fuel pump an are they plug an play OEM Airdog 2 4gen looks like is some what plug an play. Do any have advice on this don't have lots of $ am disabled veteran an on limited income but stock pump is going out an trying to keep my injectors running as long as possible. Thank you. First time asking for your all help hope I doing it right.
I was going to go with an Airdog 4G but came across some discussions about using a 6.7l fuel pump. The 6.7l has more than enough power pushing up to 120psi. You have to piece it together pump, hose, relay harness, quick connects but It’s a fraction of the cost and readily available at any parts store if it ever failed unlike the aftermarket brands. Search 6.7l 6.0l fuel Pump swap.
I also did a custom fuel bowl delete, regulated return and coolant recirculating set up with SS Lines, AN fittings for a fraction of the cost.
1 - 4 of 4 Posts
