1 - 8 of 8 Posts
Just a question would the o rings being bad cause the injectors to leak fuel into the oil?
Thanks for the reply ,how would I tell witch one is bad ?
Yes a bad o-ring or cracked injector sleeve (or head) can cause fuel to enter the oil. The work involved in finding the bad o-ring may be more than what is needed to change them all. Actually I do not know of a way to trace down a o-ring into oil leak. You may be able to put air into the system and look at all injectors for a leak.
not sure if it would work on our trucks but my boss adapted a weed sprayer to fit the fitting on big trucks at work and sprays diesel into the head to find it. but like said probably easier to change all of them.
"resident smarty pants"
In many cases, you can use UV dye in the fuel to find the leak. However, a trusted 6.0L tech told me that this doesn'r really work w/ the 6.0L.
This may work:
1 - 8 of 8 Posts
