Hey guys so I’m running out of options! Just bought this truck a couple weeks ago and was running great!
The guy I bought it from just did the HPOP, hpop up pipe and dummy pipe cause the O-ring blew or something so he put in a new one, also did the ICP,IPR and Y-pipe! New turbo and sinister blue spring kit!
To explain what’s happening:
30 minutes ago I let the truck warm all the way up to 190 degrees, oil and trans temp. FICM voltage is “showing” 47.5-48, HPOP was reading around 550-600 I believe at idle and battery voltage was showing 13.8!
Made sure it was fully warmed and then went on a cruise through the neighborhood (didn’t make it over 30mph). 2 minutes into the drive I can start feeling the motor start bouncing, or lugging! Pulled into a drive way and turned around to head back home, while in reverse it was still bouncing so to speak. *Pull in the driveway and then it really starts bucking in reverse, let it sit there in idle and it almost sounds like it’s running off of a few cylinders maybe more! *not really sure unfortunately. Then it started to get an even worse idle and gave it a little gas and it sounds like it’s missing!
here’s what’s weird though…… shut the truck off, turned key back to ON and it didn’t sound like it went though it’s full injector clicking, like 1-2 seconds and it stopped clicking. Normally it will click for 10-15 seconds….? I then cranked the truck back up no problem and acts like idle wasn’t even an issue!!!!! I guarantee if I go down the neighborhood the issue will occur all over again! I have the torque app and I’m afraid to go to a dealer that wants to throw parts at it. My pockets aren’t that deep for an 8k repair bill on injectors….
I did get a cylinder 5 contribution before I took the drive! ANY HELP would be greatly appreciated!!! I don’t know if it’s a FICM Cause I would think that it would be doing it from the start? I live in SC near Spartanburg! Once again it can run at idle all day long and it will run fine, the moment I go out on a drive is when it starts the idle bucking issue!
