1 - 5 of 5 Posts
So, I've got shopping list together of what I can afford and the other list is my build list of what I can't, but I'm simply able to build on my own. I'd be interested in wiring diagram from anyone who has built of similar years. I'm building a 04 Excursion 6.0 to a 03/04 5.9 CUmmins Common Rail sticking with my 5R110. I'm good with transmission, I just need to see the combining of the harness and the use of Ford PCM and the Cummins ECU. Also, if anyone has motor mount schematic I could sure one to compare to what I think will work. I would greatly appreciate the help with any and all you alls knowledge. Many thanks.
I know I didn't have the opportunity to get through all of later forums, but the ones I did find that applied where from 2014-15.
Administrator
There is currently two people doing this exact swap over on powerstroke.org. one is an excursion too.
Than you, I'll check it out.
Administrator
I guess i should of told you their names. One is junior125 and the other is master_chase. If I find one of the threads I'll link it here.
we could sure use one or two of those threads over here!!!
hint hint
1 - 5 of 5 Posts
