This writeup is a great help, but I've got a question on the wiring on the molex connectors. I'm essentially trying to figure out which is ground and which is +12(5A? Heat?) for heat coming from/going to the mirror connector.
I THINK from some post that "black" should be ground and "black with white" should be +12(5A? Heat?). I believe that somone posted that Black is ground and Black/white strip is heat... and based in the pic in step 7 showing the mirror side connector with those wire markings, I THINK that pin 5 should be +12, and pin 6 ground. Can anyone confirm this??
The pics in step 8 and 9 are a little confusing to me because one of the molex connectors (step 8) is shown wired with <white green empty(assuming purple will go here) black> and then a pic with a purple ground. Then step 9 pics show "A" "B" and "C" hooked up, but the molex connector is wired with <Black Black Purple White> with a black ground and purple hooked to something else.
Please don't get me wrong, the write up is very helpful... I'm just confused on this one point, and I'm thinking that pics from right and left install are mixed together a little and that wire colors are different right and left based on what wire was available during the install... so I'm just trying to clarify.
Thanks in Advance!
