1 - 13 of 13 Posts
I've been trying to figure this f 'n humming noise out for a while now. It happens when traveling 50 and 70 mph. I swapped out hub bearings twice (timken) then I tried going on 4x4 I have have manual locking hubs. It made noise wile in 4x4 clunking and squeaks. So found my hub locks were bad so I swapped out last night (warn) locks. And tried out this morning and its stil f'n their. I need help thanks
The year and model of the truck will help.
Administrator
Have you Checked the universals?
50-75 is the speed where worn universals start warning you there is an issue
How do I check for that? Is it visually?
Administrator
both..
visually look for rust around the caps.
physically grab the driveshaft and see if it moves. usually the rust is the tell tale. i have seen universals that feel perfect, but fell apart when removed.
Discussion Starter #9
Not giving up on her i swapped old universals for new one and I'm still hearing it no im starting to feel vibration as soon as I get close to 50 mph.
Differential???
Administrator
it could be.
How are the front tires?
The tires are good . I haven't rotated since I've bought them. I here the noice like its coming from the tires. But I can clearly here tge tires . Its something else besides the tire sound.
1 - 13 of 13 Posts
