1 - 4 of 4 Posts
Neither heated seats work, the switch illuminates but no power, to the seats. I tested the switches and power is getting to them but the switch input terminal on the connector isn't getting power when the button is pressed.. If I hold the button the switch input gets 12v, is this a bad switch? People say if the switch illuminates then it's getting power to the module but that's not true since the light has its own circuit and only splices power from power wire to the switch. Inputs would be great, thanks!!
Village Idiot
Is there a wire comming off the switch..does it have power.
If you remove the wires and bypass the switch or jump the two poles do the seats heat up
...ie connect the two wires with no switch. Or connect the poles..
It was hard to tell when i did since it was so cold out.. Seened like they were, im gonna say bad switch.. According to the diagram from alldata the switch input wirevis supposed to have 12v when the button is pressed, thanks for your help
Village Idiot
Spray switch with contact cleaner...may want to pull fuse first.
1 - 4 of 4 Posts
