1 - 6 of 6 Posts
Discussion Starter · #1 · (Edited)
Can You Do A Compresson Test Thur the Glow Plug 01 7.3
Can you get a good Copresson Test thru taking out the Glow Plugs on a 01 7.3? What is the Thread Size to screw the Adaptor for the Gauage to connect into the Glow Plug Hole? HELP PLEASE, THANKS
Only real way. Never seen an elaborate fitting for the injector hole, plus you'd make a mess with the oil and diesel.
Get an M10x1.0 O-Ring boss male to 1/8"NPT female adaptor. Thread in a 12" grease gun whip. On the other end, a 1/8" NPT barrel connector (female both ends)
If you don't have a diesel compression tester, get Harbor Freight's cheap one. It'll have a small 1/8"NPT adapter you can thread into your newly made adapter.
And yes, it needs to be a whip. A solid one will hit the rocker arm.
Glow plug hole is where you screw you CT fitting into. I just did a compression test on my 1500 truck today. I had 1 low hole(150lbs) Remove all your GP's before you do this test. As stated above: you must have a whip fitting.
All done now
Nope, glow plug hole is M10X1 o-ring boss. Other end of adapter needs to be 1/8th NPT to attach to the 12# grease gun whip.
1 - 6 of 6 Posts
