Can anyone who has installed a 6 leaker IC in a 7.3 say 2001 please tell
me what all is required? Are there any mods? Please help me so I don't
get into this and find a major hold up.
Dont forget you will need to tweek the trans cooler mounts.(If your still running the stock trans cooler) If I coukld do it again I would install the 6oh trans cooler at the same time.
Also make sure you do not kink any of your cooler lines. Unbolt your cooler and leave it unbolted until you get the new IC in place and you should be able to bolt back up in the same holes. those two cooler lines seem to be the only things that really get in the way.
re: tranny lines
only on a few trucks but seems like they were o1's
also joe aka ..cspid put one on his truck i believe I think he had to adjust his lines a lil.
good idea about the tranny cooler, if you cant get a 6.0 a v10 is still a great improvement and 1/3 the price.
Mike, I have a F5 DP that was "live tuned" by Scott and I generly just
run around in the 80 Econo because it seem to like it very well! Thanks
for the info.
Bill
107.5K members
