Reasonable HG & Stud Cost? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-19-2010, 09:40 PM Thread Starter
dstryr's Avatar
Called a shop around here...won't mention names but was quoted $5900 dollars for a headstud and gasket install. $3700 of that was in labor...
Is this outrageous in California? Looking for some place to go that is reasonable.
dstryr is offline
post #2 of 17 (permalink) Old 04-20-2010, 04:55 AM
95powersmoker's Avatar
Re: Reasonable HG & Stud Cost?
Seems pretty high. That would technically be 37 hours at $100/hour. Which would be almost a full work week. Seems like a performance diesel shop should be able to do it in a day maybe two at the most.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 17 (permalink) Old 04-20-2010, 04:57 AM
Powerstrokin'
cw96stroker's Avatar
Im gonna say that it seems pretty high to me.. its not that huge of a project..
2001 Platinum with sum stuff done
1996 F250 I solded it
2008 lifted duramax dually
Originally Posted by NE-STROKE View Post
Be a real man. Stop. Pull over. Then throw a stick in his spokes if you are that upset.
cw96stroker is offline
post #4 of 17 (permalink) Old 04-20-2010, 05:06 AM
Not Winning.
6.0 p-stroke's Avatar
if your getting it done, and done right, you should get your heads checked, which usually takes a day. but that does seem a little high. are you getting anything else done? could there be some other parts that are adding cost, ie: injectors, turbo, EGR delete, ect...?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
Logan Schneider at CenTex Diesel Performance
830-885-6500
Originally Posted by Powerstroked162 View Post
Lets be honest here, how many times have you been on the receiving end of a "Cleveland Steamer"?
6.0 p-stroke is offline
post #5 of 17 (permalink) Old 04-20-2010, 02:48 PM
He said most of that was labor...
Which means they plan on having this thing in the shop for a week. Which i believe unless they got head stud and gasket mixed up with entire engine rebuild then the price is too high.
James
post #6 of 17 (permalink) Old 04-20-2010, 03:55 PM
Not Winning.
I understand that, but even with 3700 dollars in labor, that leaves 2200 dollars in parts, subtract about 500 for studs and 400 for gaskets, that leaves 1300 dollars in other parts, where is the other money going?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #7 of 17 (permalink) Old 04-20-2010, 04:48 PM
NHRDA Diesel TV Host
Luvin_her_stroker04's Avatar
Have you ever done headstuds on a 6.0? It is a full week. It's a day to pull the cab and heads, day or so at the machine shop, day to do studs and day for reinstalling the cab, doing the ac and buttoning up. Although 37 hours is a lot. Most shops charge 25-30 depending on the machine shop services getting done. That's just my .02
'04 F350. Typical Mods with tuning by Tadd and Eric and Matt.
'06 VW Jetta TDI. Stock. 42mpg
Sticks and stones can break my bones, but Fords with big turbos excite me...
Originally Posted by SevenThree View Post
People think I like girls because guys worth my time are as easy to find as crew cab powerstrokes in the 11's.
Luvin_her_stroker04 is offline
post #8 of 17 (permalink) Old 04-20-2010, 05:20 PM
Just called the dealership and they will do if for 2250 which includes labor and gaskets and then 500 bucks for studs so a total of 2750.
James
post #9 of 17 (permalink) Old 04-20-2010, 06:40 PM
yeah i talked to the diesel tech a the ford dealer and he said let him know a couple weeks in advance and he would do it in his spare time on the weekend for 2000 and hes gunna do egr headstuds and injectors and i also asked the local diesel diesel shop thats has do work on my 7.3 and he said 2500 for labor so yeah thats to much
6.0 220k..4"silverline tubo bak..k&n ..sctw/custom tunes egr delete 35" bfg km2 on black bullet holes
ford: 97 350 389k r.i.p murdered by semi. 93 1st gen lighting 351w afr's,holley,ford racing
06stroker250 is offline
post #10 of 17 (permalink) Old 04-20-2010, 08:10 PM
rollin coal!
Prew32's Avatar
ya that is way expensive for labor, Im looking into getting mine done right now and the two shops I have talked to wanted around 2100 for labor. I think i might take mine to a ford diesel tech for him to do as a side job he charges almost half price
Prew32 is offline
