Old Fashion Days Pull "Fall Fleece Pull" Sept 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-05-2011, 04:31 AM Thread Starter
paul06d-max's Avatar
On Sept 3 we will be haveing our annual sled pull in North Salem, IN
Classes will be the same as the spring pull 2.5, 2.6, 3.0
Hope to see everyone there....
I'll link the rules in soon...
Thanks Paul
06' LBZ
Suncoast 1057 Raybestos Clutches
FPE S366
75% over Exergys
Stock Engine Factory Head Bolts!
Special Thanks to Fleece Performance!!
paul06d-max is offline
post #2 of 5 (permalink) Old 08-19-2011, 01:51 AM Thread Starter
Re: Old Fashion Days Pull "Fall Fleece Pull" Sept 3
Old Fashioned Days "Fall Fleece Pull" Classes and Rules
1. Work Stock Class
・ True 2.5” Inducer Bore NO CLIPPED WHEELS / NO BUSHINGS / NO
TAPERED COVERS
・ .200 MAX mwe Groove
・ No Hanging Weight Beyond Front Bumper (Ballast Permitted)
・ 8000lb Maximum (With Driver)
・ 26” Hitch Height
・ DOT Tires
・ No Dual pumps, no compressed gases or Power Adders of Any Kind
・ Diesel Fuel Only
・ Traction bars are allowed
・ Valid Registration and Proof of Insurance Required
・ Single Wheel Trucks Must Run Single Rear Tires, Factory Dual
Rear Trucks are Permitted to Run Dual Rear Wheels
2. Hot Street
・ 2.6” Inducer Bore
・ Minimum 1/8" Protrusion Into Bore
・ Hanging Weights are permitted within 60” from axle CL
・ 8000lb max (With Driver)
・ Driveshaft loops, u-joint shields and bump stops required
・ Dual pumps are permitted
・ No compressed gases of any kind
・ No Water/Meth
・ 26” Hitch Height
・ DOT Tires
5. Super Street
・ 3.0” Inducer Bore
・ .250 MAX mwe Groove
・ 8000lb max (with driver)
・ Water Injection Permitted No methanol
・ 26” Hitch Height
・ DOT Tires
We will also have a stock class....
Paul
06' LBZ
FPE S366
75% over Exergys
post #3 of 5 (permalink) Old 08-30-2011, 03:00 AM Thread Starter
bump
06' LBZ
FPE S366
75% over Exergys
post #4 of 5 (permalink) Old 08-30-2011, 03:12 AM
This is a awesome pull to go to. I'm in a wedding so I can't go. If you're free, be there!
More than you
diesel dane is offline
post #5 of 5 (permalink) Old 08-31-2011, 02:53 AM
Ill be there spectating.
late 99 black CCSB
OUTLAW101 is offline
