Noise at around 50 mph - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 12-28-2010, 12:54 AM Thread Starter
th3godf4th3r's Avatar
so we are starting to get a noise at around 50 mph, its coming from around the engine or the front right wheel i think
it sounds like a squeaking with vibration and sounds like something is falling off or is coming apart. it last from anywhere in between 1-6 seconds then goes away.
could it be a pulley thats loose or something? or even something in the engine itself? its going in for its first oil change tomorrow at 8400 miles. we are in eastern washington hunting however and dont want the truck in the shop for long with them trying to figure it out.
any ideas?
2011 Ford F-350 King Ranch 4x4 CC LB
2008 Ford F-150 Lariat 4x4 CC SB
th3godf4th3r is offline
post #2 of 8 (permalink) Old 12-28-2010, 01:11 AM
Re: Noise at around 50 mph
does it matter what rpms your turning at 50? I doubt its tranny related, but if its higher pitched with higher rpms I'd suspect a pully. Does it do it with the A/C on/off?
If it was engine (or anything on the engine) related I would suspect it would be more rpm dependant instead of speed dependant, but I could be wrong.
'11 F250 Crew Cab Short Bed XLT FX4 Midnight Black
Wheels11 is offline
post #3 of 8 (permalink) Old 12-28-2010, 01:50 AM Thread Starter
seems to be around 1500-2000 rpm i think. too cold for the a/c here but we can try tomorrow.
i think its a pulley but ill have them check everything tomorrow
hopefully its nothing too serious
post #4 of 8 (permalink) Old 12-28-2010, 03:32 AM
BIGCSS's Avatar
It may be to cold for you to turn on the a/c, but if you use your defroster they use the a/c to help dry the air to help defrost faster. So it still could be a/c related.
2011 F-450 Lariat 4x4 (Ingot Silver) w/American Force 19.5's
2000 F-350 CCLB XLT 4x4 (Oxford White)
BIGCSS is offline
post #5 of 8 (permalink) Old 12-28-2010, 03:34 AM Thread Starter
hmmm, ok well i will bring it up to the tech tomorrow.
thats possible but only hitting around 50 mph? it has happended at 30 mph too but its almost always around 53 mph. and i correct myself, usually happens between 1000-1500 rpm
post #6 of 8 (permalink) Old 12-28-2010, 02:47 PM
Keep us posted. It could be the way it shifts that is keeping it above the rpm that your noticing the problem at until it goes into OD. Just a thought. You might play with the manual shift to see if you can make it happen more consistently. Hope its nothing serious
Wheels11 is offline
post #7 of 8 (permalink) Old 12-30-2010, 09:11 PM Thread Starter
well naturally when my dad has the tech riding along it doesnt happen.
i wont jump the gun here but it seems to only happen in e. washington and not here in seattle. we will drive it around at that speed here and try to get it but i dont think it will happen
post #8 of 8 (permalink) Old 12-30-2010, 11:07 PM
Thats frustrating. Good luck.
Wheels11 is offline
