Afe Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-25-2010, 06:10 PM Thread Starter
th3godf4th3r's Avatar
Afe Questions
hey guys
got my dad the afe intake value pack for xmas and it comes with the pro guard dry S filter (grey) and the pro guard 7 filter (gold one)
which one should we go with? and should i use the filter cover bag to further filter dirt?
thanks guys
merry xmas!
2011 Ford F-350 King Ranch 4x4 CC LB
2008 Ford F-150 Lariat 4x4 CC SB
th3godf4th3r is offline
post #2 of 5 (permalink) Old 12-25-2010, 08:52 PM
The Diesel Cartel
InMotionJosh's Avatar
Send a message via AIM to InMotionJosh
Re: Afe Questions
Not to take away from your thread but I'm wondering if these intakes will throw any codes without tuning
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #3 of 5 (permalink) Old 12-25-2010, 09:07 PM Thread Starter
Re: Afe Questions
is does come with a TSB message with the screws and everything saying that heavy rain and snow can clog it
but they also say if throws code P whatever then take it to ford, ill post what it says when im done.
after installing most of it, i really am dissapointed with the fit of the airbox, its pretty tight and rubs on the a/c evac(?) pipe. i had some wire loom tubing so i put that around it
post #4 of 5 (permalink) Old 12-25-2010, 09:46 PM
BIGCSS's Avatar
Re: Afe Questions
I have been running one of the Prodry S filters in the stage 2 intake since the truck was only 3 or 4 weeks old. I haven't had any check engine lights and I don't plan on doing any tunes to at this point. I do use the prefilter bag also and did on my previous truck. The nice thing about the pre-filter is you rarely ever have to clean the main filter, just take the pre-filter off and wash it and then when it's dry reinstall it. These do fit pretty tight into the new superduties, but I didn't have any issues with it possibly rubbing on things.
2011 F-450 Lariat 4x4 (Ingot Silver) w/American Force 19.5's
2000 F-350 CCLB XLT 4x4 (Oxford White)
BIGCSS is offline
post #5 of 5 (permalink) Old 12-25-2010, 09:51 PM Thread Starter
Re: Afe Questions
well i got it all in and so far so good, just drove it around the block.
did seem to take a little bit longer to spool up the turbo but maybe its the same.
ok well i put the 7 filter in with the pre-filter. Ill keep it on for awhile then ill try the dry S one.
the TSB was about the wastegate accuator fyi
