Need help with amp steps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-18-2010, 07:31 PM Thread Starter
th3godf4th3r's Avatar
hey guys, getting to the wiring portion of the amp steps and the instructions that came with the steps i dont think have the right wiring diagram
anyone with the 2011 amp steps know which wires on the passenger side tap into the wires from the amp steps?
my directions say
yellow to yellow
dark green w/ stripe to same
dark green to same
white to white
i dont see a solid white wire and tapping into the two yellow solid wires i saw didnt work
any help would be great
thanks!
2011 Ford F-350 King Ranch 4x4 CC LB
2008 Ford F-150 Lariat 4x4 CC SB
th3godf4th3r is offline
post #2 of 11 (permalink) Old 09-18-2010, 07:46 PM
OOWeaver68's Avatar
Re: Need help with amp steps
I just got done putting these on my 2008. If its the same as mine, the white wire is up in the flat wire loom towards the front. Then there are 2 yellow, tap into the one that goes to the back seat and not the one that goes under the front seat. Tug on it and you can tell. Make sure you have a good connection, I wasnt getting a good connection and I thought I was on the wrong wire, so I spent close to an hour trying to figure it out.
My directions called for a dark green wire, I didnt have any dark green wires in my truck.
Hope this helps.
OOWeaver68 is offline
post #3 of 11 (permalink) Old 09-18-2010, 08:13 PM Thread Starter
i got the drivers side working but i will try that for the passenger side now weaver
post #4 of 11 (permalink) Old 09-18-2010, 08:26 PM Thread Starter
got it! you were right, dont know why but i got different directions with the kit
oh well! works now!
post #5 of 11 (permalink) Old 09-18-2010, 09:42 PM
OOWeaver68's Avatar
Good deal. These steps are nice aint they.
post #6 of 11 (permalink) Old 09-18-2010, 10:09 PM
Village Idiot
LRTMatt's Avatar
My steps should be here by the end of the week, but the truck wont' be here for at least 2 weeks! I've wanted AMP steps for about 3 years now and a new truck was excuse enough to get them!
LRTMatt is offline
post #7 of 11 (permalink) Old 10-09-2010, 09:08 PM
Village Idiot
LRTMatt's Avatar
Well the white wire is eluding me. There is no flat loom in this truck and every white wire in that area has a colored stripe on it.
LRTMatt is offline
post #8 of 11 (permalink) Old 10-09-2010, 11:11 PM Thread Starter
its on the passenger side, you have to remove the kick panel and it is right where the kick panel would be, the white wire was hiding in there but its in there.
basically just follow the wires up from where the others are tapped in
post #9 of 11 (permalink) Old 10-09-2010, 11:16 PM
Village Idiot
LRTMatt's Avatar
Thanks, I will dig deeper into that harness tomorrow. Every damn white wire I found so far has a colored stripe on it!
LRTMatt is offline
post #10 of 11 (permalink) Old 10-10-2010, 02:06 AM Thread Starter
yeah thats what i was having trouble with but its up there!
