Smoked markers and tails - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 08-14-2010, 03:53 AM Thread Starter
Moved in
sagebel's Avatar
Finally worked up the nerve to tint the marker lights and brake lights. I used VHT Nightshades. Seemed to turnout alright.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #2 of 22 (permalink) Old 08-14-2010, 04:08 AM
Send a message via Yahoo to needalaugh
Re: Smoked markers and tails
looks great! where did u get the tint at?
needalaugh is offline
post #3 of 22 (permalink) Old 08-14-2010, 04:10 AM
jdgleason's Avatar
Ya... looks awesome!
'09 F350
-JD
jdgleason is offline
post #4 of 22 (permalink) Old 08-14-2010, 04:20 AM
my other ? is u can use that tint on the headlights to cant you?
post #5 of 22 (permalink) Old 08-14-2010, 04:21 AM Thread Starter
Moved in
sagebel's Avatar
Napa had it. Most parts stores are starting to carry it.
sagebel is offline
post #6 of 22 (permalink) Old 08-14-2010, 04:28 AM
sweet looks like i know what im pickin up tomorrow
post #7 of 22 (permalink) Old 08-26-2010, 06:07 PM
Relentless1's Avatar
Did the same to my truck with the tails and 3rd brake. Came out awesome. I much prefer the look to a recon light which i think are a bit cheesy. Make sure you sand between coats and shoot it with clear to finish it off otherwise the VHT will turn chalky.
2013 F-250 CC Lariat Ultimate
Morimoto 55w HID kit
22x9.5" Fuel Hostage
325/50R22 Toyo Open Country A/T2 Extreme
RBP light Bar
4 x PIAA 520ATP lights
RBP RX-3 Side steps
Relentless1 is offline
post #8 of 22 (permalink) Old 08-26-2010, 07:07 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
What kind of clear are you using over the VHT. I think I used acrylic, maybe enamel, not sure, whichever it was is all cracking and pealing. Want to redo them with the right stuff.
BTW, truck looks great Sagebel.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #9 of 22 (permalink) Old 08-26-2010, 09:01 PM
Jeff @ Spartan's Avatar
I prefer Recon, but it looks pretty good.
Jeff Dodd
2012 Ford F-250 CC/SB
Jeff @ Spartan is offline
post #10 of 22 (permalink) Old 08-26-2010, 09:15 PM
wheres the fat chicks?
PowerstrokeR00's Avatar
Can someone make a pretty detailed right-up on each step it takes to tint your tail lights/3brake light yourself?I really want to tint mine but dont want to screw up.
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
