Smoked markers and tails - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 22 (permalink) Old 08-26-2010, 09:28 PM
Relentless1's Avatar
Re: Smoked markers and tails
I used Rust Oleum Touch up CC 1000 Clear. Seems good so far but I just did mine 2 weeks ago so only time will tell.
2013 F-250 CC Lariat Ultimate
Morimoto 55w HID kit
22x9.5" Fuel Hostage
325/50R22 Toyo Open Country A/T2 Extreme
RBP light Bar
4 x PIAA 520ATP lights
RBP RX-3 Side steps
Relentless1 is offline
post #12 of 22 (permalink) Old 08-27-2010, 02:59 AM
I just installed the recon tail lights on my truck this evening. I like the led lights but I don't care for the dated look it gives the rear end of the truck. If I sprayed my stock lights is it possible to tape over your backup lights because I hook up a lot of trailers and u can't hardly see the hitch on the nav screen. It reminds me of my 03 stock tail lights. I may be returning and going your route. I like the smoked mirror leds and clearance lights though. Oh an I installed my hornblasters today. Great addition!
pipeliner11 is offline
post #13 of 22 (permalink) Old 09-02-2010, 07:20 PM
Power Smoker's Avatar
Hopefully none of you will copy the duche bag I almost killed a couple weeks ago. Some pizza delivery boy in his old hatchback civic had his tail lights so darkly tinted that I didn't see his brake lights, or left turn signal (in the middle of the afternoon) until the nose of the bronco (at 65 mph) was within 20 feet of his rear bumper, as I was passing, and he started to turn into me. I'm sure I would've killed him if he didn't see me coming, and take serous evasive action as the bumper was pretty even with his head through the window. The tint works great, and looks nice on a lot of rigs, but there's a wrong way to do it.
Power Smoker is offline
post #14 of 22 (permalink) Old 09-02-2010, 07:23 PM
Was PSD0389
Matt_P's Avatar
yeah you dont ever want to go over 3 coats, otherwise stuff like that is gonna happen
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
post #15 of 22 (permalink) Old 09-02-2010, 07:28 PM
looks nice.
03_PSD is offline
post #16 of 22 (permalink) Old 09-02-2010, 07:57 PM
F-117HWK's Avatar
Originally Posted by PowerstrokeR00 View Post
Can someone make a pretty detailed right-up on each step it takes to tint your tail lights/3brake light yourself?I really want to tint mine but dont want to screw up.
This is the process I used to do my side markers on my Trans Am. One of the members over on LS1Tech did this write up. Keep in mind all this is for a Trans Am so amount needed may be different for the truck.
Difficulty: Easy
Time: 1-2 hours application. (A lot of downtime waiting for it to dry.) + 6 Hours for final dry.
Tools needed:
(2) Cans VHT Nite-Shade (summit racing)
** Note: 2 Cans are recommended so that you dont run out in mid project, however you may not need the 2nd can, the amount used varys per application. In situation, I used both to the last drop. I'd say play it safe for the extra $10. **
(1) 3m Scuff Pad (advance auto)
(1) Can Clear Coat (BIG_MIKE Suggests Duplicolor Truck/SUV Clear Coat, the generic crap I used started to fade in about a year, so apply generous coats and use quality stuff! Let me know if you've used anything you'd recommend for long lasting shine.) ... lol I sounded like a bad infomercial.
(1) Windex / Similar Product
(1) Microfiber (recommended but not mandatory)
Steps:
1) Remove parts to be blacked out.
2) Clean all parts with windex and microfiber.
3) Scuff with 3M Scuff pad to prep surface.
4) Wipe excess dust with microfiber.
5) Place 2-piece items side by side, (ie taillights, passenger side corners... etc.)
6) Spray even short bursts across both items as if they were one item to ensure even coating.
7) Wait until the Nite Shades becomes tacky and repeat until desired darkness is reached ( I used about 6, but coat thickness varies, so dont use that as a gauge.)
8) Upon completion of Nite Shades wait about 30 minutes for it to semi-dry, then begin to apply clear coat spray. *Note: When I applied the first coat, I lost most gloss of the nite shades, dont be discouraged, wait til tacky and apply again, repeat until shine is restored.*
9) Wait roughly 6 hours before putting parts back in their original place on vehicle.
2006 F-250 CC Lariat 4x4
F-117HWK is offline
post #17 of 22 (permalink) Old 09-02-2010, 08:27 PM
Was PSD0389
Matt_P's Avatar
What I normally do is scuff up the tail lights with 000 steel wool
Then clean it off with an auto prep spray and then wipe down with a tack cloth
Then if anything needs to be taped off, reverse lights or anything like that, now is the time.
Then I spray on the night shades up to three coats. Depends on how dark its gonna be.
Then let it dry for an hour and wet sand with 800 and then 1500 grit.
Then clean off with water and a tack cloth
Then spray 3 coats of clear coat waiting ten minutes between coats. I have use dupli color clear and now I use a higher quality clear that gives it a much better shine
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #18 of 22 (permalink) Old 09-03-2010, 02:13 AM Thread Starter
Moved in
sagebel's Avatar
I did two light coats on my tails. They are still light enough to reflect light.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #19 of 22 (permalink) Old 09-03-2010, 02:15 PM
wheres the fat chicks?
PowerstrokeR00's Avatar
what clear do you all recommend that will last a long time?
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #20 of 22 (permalink) Old 09-03-2010, 05:10 PM
Was PSD0389
Matt_P's Avatar
i use the clear from automotivetouchup.com
It gives it a nice gloss. Here is a set of Jeep lights I did with that clear
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
