BDS Releases 1", 2", 4" & 6" Kits - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-02-2010, 11:44 PM Thread Starter
SAK
BDS 1", 2", 4" & 6" lifts have been released.
1" Spacers - $249.76
BDS 1 Inch Spacer Kit - 2011 F250/350 SRW 4wd - This kit includes two lower coil spring spacers. The spacers are machined from solid 6061 Aluminum to help level out your vehicle. Th kit also includes new ball joint alignment cams allowing you to properly align your vehicle. Lifetime Warranty
2" Spacers with Shocks - $321.35
BDS 2 Inch Spacer Kit - 2011 F250/350 SRW 4wd - This kit includes two lower coil spring spacers. The spacers are machined from solid 6061 Aluminum to help level out your vehicle. Th kit also includes new ball joint alignment cams allowing you to properly align your vehicle. Lifetime Warranty
Both 4" & 6" kits are available with drop radius arm brackets or 4-link. The 4" kit is available with rear blocks or springs and the 6" only comes with rear springs.
4" with blocks - $1,138.98
BDS 4 Inch Suspension System - 2011 F250/350 SRW 4wd - This kit centered around two Pro-Ride coil springs. The box kit includes two new radius arm drop brackets to put the stock radius arm back at factory angle which will maintain your stock driving characteristics. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted via a 5" block kit that eliminates the factory block. Lifetime Warranty
4" with springs - $1,922.65
BDS 4 Inch Suspension System w/Rear Springs - 2011 F250/350 SRW 4wd - This kit centered around two Pro-Ride coil springs. The box kit includes two new radius arm drop brackets to put the stock radius arm back at factory angle which will maintain your stock driving characteristics. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted with new BDS Glide-Ride leaf springs. Lifetime Warranty
4" 4 Link with blocks - $1,964.26
BDS 4 Inch 4-Link Suspension System - 2011 F250/350 SRW 4wd - Why a 4-link system? It's simple, with 10" of wheel travel there is less than 1 degree of caster change (front axle rotation), this means control in the steering wheel over rough terrain. The stability in the steering wheel is noticable even under normal driving conditions. In addition to 4 beefy control arms, this kit comes with new 4-link frame mounting brackets. These aren't a drop down bracket, they actually replace the stock mounting system. -Don't worry, no welding required. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted via a 5" block kit that eliminates the factory block. Lifetime Warranty
4" 4 Link with rear springs - $2,747.90
BDS 4 Inch 4-Link Suspension System w/Rear Springs - 2011 F250/350 SRW 4wd - Why a 4-link system? It's simple, with 10" of wheel travel there is less than 1 degree of caster change (front axle rotation), this means control in the steering wheel over rough terrain. The stability in the steering wheel is noticable even under normal driving conditions. In addition to 4 beefy control arms, this kit comes with new 4-link frame mounting brackets. These aren't a drop down bracket, they actually replace the stock mounting system. -Don't worry, no welding required. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted with new BDS Glide-Ride Leaf Springs. Lifetime Warranty
6" with rear springs - $2,112.31
BDS 6 Inch Suspension System w/Rear Springs - 2011 F250/350 SRW 4wd - This kit centered around two Pro-Ride coil springs. The box kit includes two new radius arm drop brackets to put the stock radius arm back at factory angle which will maintain your stock driving characteristics. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted via new Glide-Ride leaf springs. Lifetime Warranty
6" 4 Link with rear springs - $2,872.03
BDS 6 Inch 4-Link Suspension System w/Rear Springs - 2011 F250/350 SRW 4wd - Why a 4-link system? It's simple, with 10" of wheel travel there is less than 1 degree of caster change (front axle rotation), this means control in the steering wheel over rough terrain. The stability in the steering wheel is noticable even under normal driving conditions. In addition to 4 beefy control arms, this kit comes with new 4-link frame mounting brackets. These aren't a drop down bracket, they actually replace the stock mounting system. -Don't worry, no welding required. The kit also comes with a new steering stabilizer, anti-sway bar drop brackets, a dropped pitman arm for steering angle correction, a track bar relocation bracket to properly center your axle and bump stop extension. The rear is lifted with new BDS Glide-Ride Leaf Springs. Lifetime Warranty
All Kits can be found in our ONLINE STORE
SAK is offline
post #2 of 3 (permalink) Old 08-03-2010, 03:04 AM
Moved in
sagebel's Avatar
Re: BDS Releases 1", 2", 4" & 6" Kits
What tire size will each kit clear?
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #3 of 3 (permalink) Old 08-04-2010, 09:02 AM Thread Starter
SAK
4" will clear 35's and 6" will clear 37's.
SAK is offline
