Help with some intercooler boots blowing off! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 05-15-2010, 12:55 AM Thread Starter
Young'n
powerstrokeracing's Avatar
well i got a 1997 f-350 and ihave a BFH turbo on it and of course its intercooled, these boots just keep blowing off. and there leaking somewhere cause all i can get out of it is 40psi of boost MAX. so obviously these clamps arent holding tight? or im doing something wrong? any help would be great!
TIA
powerstrokeracing is offline
post #2 of 40 (permalink) Old 05-15-2010, 01:26 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Help with some intercooler boots blowing off!
make sure you didn't crush the plenums...clean boots and where they attach with something like brake clean...spray the inside of the boots with hair spray and clamp them down...the hair spray will act like glue and make the boots stick..
Ron's power stroke is offline
post #3 of 40 (permalink) Old 05-15-2010, 01:31 AM Thread Starter
Young'n
just pulled the passenger side plentum off and re sealed it cause it was leaking, im sure there fine, idk how they would have got crushed but ill try that, Thanks!!
post #4 of 40 (permalink) Old 05-15-2010, 01:35 AM
if you go to tight with the clamp..you can crush them...
post #5 of 40 (permalink) Old 05-15-2010, 01:35 AM
Village Idiot
southmike's Avatar
They crush cause they are just sheet metal.
Cspid aka joe knows a link to a good insert you can put in.
It allows you to tighten the clamp a lot more
southmike is offline
post #6 of 40 (permalink) Old 05-15-2010, 01:38 AM Thread Starter
Young'n
yall got me scared to tighten them now. how tight is to tight?
post #7 of 40 (permalink) Old 05-15-2010, 01:40 AM
riff raff has the incerts..but i think there only for the 3 inch plenums...
post #8 of 40 (permalink) Old 05-15-2010, 01:44 AM
here it is...it doesnt say the size...
Riffraff Diesel: RDP Plenum Reinforcing Inserts™
untill it feels tight lol..cant remember the TQ spec..give a few...ill look around..
post #9 of 40 (permalink) Old 05-15-2010, 01:47 AM Thread Starter
Young'n
ok thanks a ton, and BTW i do have 3 inch plentums.
post #10 of 40 (permalink) Old 05-15-2010, 02:08 AM
Recommended torque is 60 in/lbs on a t-bolt spring clamp..this will also depend on how strong your plenums are..
You may not post new threads
You may not post replies
