Zoodad Mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 06-20-2010, 11:45 AM Thread Starter
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Post Zoodad Mod
To begin this mod, You will need a long flat head screw driver, a phillips heads, and a cutting tool of your choice, saw zaw, or hole saw can work as well. Removal of the airbox is a good idea as well give you room to cut through.
Step 1
Start by removing the 4 screws located on thop of the Grill, here shown in picture one for locations. Using the Phillips Head Screw Driver
Step 2
Next using the flat head screw driver run it between the grill and bumper, your going to want to lift these tabs and pull the grill out a little to have it pop out, there are 4 located under the grill.
Step 3
Location of the hole is shown in picture below, size and shape can be done by the owner, I just hacked mine out no big deal, if you want to take the time have at it. This part of the header panel is located on the driver side between the out edge of the header panel and condensor. Shown in the next photo.
Full View
Once your hole is cut reverse the steps of removing the grill, place the bottom of the grill in first press slightly left to right, or Right to left making sure each tab is snapped into place, once completed reinstall the 4 screws located on top.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
Closed Thread
You may not post new threads
You may not post replies
