Update SCT Liveload Software - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-15-2007, 11:05 PM Thread Starter
Super Moderator
weweld's Avatar
This is the latest software to use but return your truck to stock before doing this
http://www.sctflash.com/forum/showthread.php?t=7666
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #2 of 11 (permalink) Old 07-24-2007, 06:01 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: Update SCT Liveload Software
Why would I need to do that, if i dont could I still upload my files anyways ?
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 11 (permalink) Old 07-25-2007, 05:09 AM Thread Starter
Super Moderator
weweld's Avatar
If you want to run the most current tunes I believe you need this for the tuner to work.
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #4 of 11 (permalink) Old 07-25-2007, 06:15 AM
The Unseen Mod
RescueF250's Avatar
So only if I get new tunes, but if i keep my old tunes and only those i should have to worry correct.
03 Rescue is Dead
post #5 of 11 (permalink) Old 07-26-2007, 04:54 AM Thread Starter
Super Moderator
weweld's Avatar
YUP
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #6 of 11 (permalink) Old 07-26-2007, 01:02 PM
The Unseen Mod
RescueF250's Avatar
kool than all I needed to know, put my truck back to Looney when I get home
03 Rescue is Dead
post #7 of 11 (permalink) Old 10-23-2008, 03:51 PM
what happens if i did not put it to stock when updated it
2003 f250 4dr, short box, gray metal flake paint with hand painted pin stripes, sct livewire tuned by elite, zodad, and 4 in to cat 6 in from cat.
1989 s10 primer gray 26psi supercharged 406, forged crank rods pistons, full roller valve train, Built trubo 350, 4link 7.5in 10bolt with 4.11. on 10.5 in of ruber. Runs 10.8 at milehigh
chody19 is offline
post #8 of 11 (permalink) Old 10-23-2008, 03:58 PM
HarleyEdition78412's Avatar
You're screwed!!!
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #9 of 11 (permalink) Old 10-23-2008, 04:01 PM
Originally Posted by HarleyEdition78412 View Post
You're screwed!!!
I think you lose your stock file so i hope you don't need to go back to stock.
Harohunter is offline
post #10 of 11 (permalink) Old 10-29-2008, 01:17 PM
w_huisman's Avatar
There should be a way to copy your stock file to your hard drive, so you have it someplace other than inside the Xcal.
2006 F250 6.0 Lariat cc sb 4x4 auto 67k
coolant filter, analog FP gauge + Edge Insight w/ EGT
VXCF9117 strategy
w_huisman is offline
You may not post new threads
You may not post replies
