FORD TRUCKS F250 6.0L 8-cyl Turbo Diesel LUBRICANTS & FLUID - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 06-20-2010, 12:34 PM Thread Starter
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Post FORD TRUCKS F250 6.0L 8-cyl Turbo Diesel LUBRICANTS & FLUID
Saw this list think should add this.
Engine Oil
Grade 1......CI-4+
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT)
SAE 15W-40 Synthetic Blend Diesel Oil (PCOQT)
Synthetic 5W-40 Premium Diesel Oil (DEOQT)
Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil (HDDQT)
-9 To 90F......10W-30 [1]
-20 To 30F......5W-30, 5W-40 [2]
-20 To 0F......0W-30 [2]
above 10F......15W-40 [3]
Manual Transmission,S6-650 W/O COOL......MA
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Manual Transmission,S6-650 W/ COOL......MA
Automatic Transmission,TorqShift......MSP
Low Viscosity Synthetic ATF (ATLQT)
Automatic Transmission,4R100......MA
Limited Slip Differential, Rear Ford......GL-5*
All TEMPS......75W-140 [4] [5]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Limited Slip Differential, Rear Dana 135......GL-5*
All TEMPS......75W-140 [5]
Standard Differential, Rear Ford......GL-5
Standard Differential, Rear S110, S130......GL-5
Limited Slip Differential, Rear Dana 80......GL-5*
All TEMPS......75W-90 [5]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Differential, Front......GL-5
All TEMPS......90
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Transfer Case,......MA
Fluids
Power Steering Fluid......MA
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] Ford TSB 05-16-6 states that SAE 10W-30 is acceptable
to use in operating temperatures from -1 C (31 F) to
32 C (90 F).SAE 10W-30 is the preferred viscosity if the
operating varies from -20 C (-4 F) to -1 C (31 F).
[2] Ford TSB 05-16-6 states that the shown viscosity is
acceptable to use in the shown temperature range.
[3] Ford TSB 05-16-6 states that SAE 15W-40 is acceptable
to use in operating temperatures from -12 C (11 F) to
-1 C (31 F). SAE 15W-40 is the preferred viscosity if the
operating is above -1 C (31 F).
[4] Synthetic oil is required.
[5] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or
equivalent formulated to meet Ford Spec EST-M2C118-A
for complete refill of limited slip axles.
FILTERS:
Oil Filter AMSOIL Ford 6 L Oil Filter (SDF88)
Oil Filter P550528 Oil Filter
Air Filter INJEN-AMSOIL Air Intake System (PF9050P) [1]
Air Filter INJEN-AMSOIL Air Intake System (PF9049P) [2]
Air Filter P603577 Power Core Air Filter [3]
Air Filter [4]
Air Filter WIX 49490 Air Filter [5]
Air Filter WIX 42731 Air Filter [3]
Cabin Air Filter
Fuel Filter Fuel Filter for Ford 6.0L Diesel Powerstroke Applications (FFK60)
Fuel Filter WIX 33899 Fuel Filter
Transmission Filter WIX 58624 Auto Tran Filter [6]
Transmission Filter WIX 57702 Auto Tran Filter [7]
[1] INJEN Filter Kit With MAF Sensor
[2] INJEN Filter Kit Without MAF Sensor
[3] Std. Power Core Version
[4] Flame Retardant version of 49490
[5] Can be used to replace Power Core element 42731
[6] 5R110W
[7] By Element
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class Driver Passenger
ExactFit T201 T201
NeoForm T16200 T16200
Winter T37205 T37205
CHASSIS LUBRICATION:
2WD
4-10 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR)
4WD
0-7 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter..........15.1 quarts [1]
Cooling System, Initial Fill..........27.5 quarts [2]
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 4R100 Initial Fill..........6.5 quarts
Automatic Transmission, TorqShift Initial Fill..........7.6 quarts
Automatic Transmission, Total Fill
4 speed 26 Plate 4R100..........17.7 quarts
4 speed 20 Plate 4R100..........17.1 quarts
5 speed TorqShift..........19.1 quarts
Manual Transmission, 6-SPD W/O OCOOL..........11.7 pints
Manual Transmission, 6-SPD W/ OCOOL..........12.7 pints
Manual Transmission, 5-SPD ZF..........6.8 pints
Manual Transmission, S6-650 W/ COOL..........12.7 pints
Manual Transmission, S6-650 W/O COOL..........11.7 pints
Differential, Dana 50 Front..........3.9 pints
Differential, Dana 60 Front..........5.8 pints
Differential, Dana 135 Rear..........23.3 pints
Differential, Dana 80 Rear..........8.5 pints [3]
Transfer Case, ..........4.1 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Includes heater and 5.0 qt (4.7L) in coolant recovery
[3] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES:
Oil Drain Plug.....32 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
Transfer Case NV271
Fill Plug 20 ft/lbs
Drain Plug 20 ft/lbs
All TEMPS......90
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
Closed Thread
You may not post new threads
You may not post replies
