Elite H-11 and ARP studs comparison - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 11-05-2010, 03:01 AM Thread Starter
idkillinit's Avatar
Ok so I've got it. First off I want to tell ellite they use one he'll of a great material. These studs will be able to be re torqued many times and are safe well above 300ft lbs. I would torque 30 or so ft lbs higher every time the are retorqued tho.
So the H-11 studs torqued at 190 ft lbs make 31,992psi of load and that's at just 60% of yeild. Amazing
The ARP-1000s torqued at 325 ft lbs make 37944 psi of load bit that is torqued at 85% of yeild. ARP claimed 75%. Liars.
The yeild strength of H-11 is 215,000 and ARP is 180,000.
Conclusion is they both work and the ARP is plenty sufficiant but if you plan on your motor coming apart more than one time after installation spent the money and get the H-11. Now for people like myself who don't plan on making more than 700 whp the arps work just fine and have a higher clamping force initallly. But of you are unsure of your future plans go with ELITES H-11.
Hope this helps. Please don't make me post all my math and formulas esspecially since my studs lost. Lol. Take forever
2008 ccsb lariat. Job1. Intake, exhaust, MPD egr delete with tial 44mm gate, 4" downpipe, cold side ic pipe,suncoast trans and convertor, live tuning from ERIC @ Innovative.
Special thanks to Eric and Ted at Innovative Diesel performance and Craig and Chris from MPD.
idkillinit is offline
You may not post new threads
You may not post replies
