Turbo rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-12-2010, 02:21 PM Thread Starter
Blk350on20s's Avatar
Turbo rebuild
Hey guys. I have 2 sets of turbos for my truck. The tech says one of the turbos that was on the truck was bad and the other was close. The LP endplay was .015 and the RAD was .025. The HP end play was .004 and the RAD was .022. Is that bad? The other set doesnt really have an in/out play but it does have up and down play.
Does anybody on this site rebuild turbos? I called ford and they cant get parts. Just new turbos.
Thanks. Ryan
Blk350on20s is offline
post #2 of 9 (permalink) Old 08-12-2010, 02:54 PM
Re: Turbo rebuild
If all of the oil is out of the bushing housing you will have some movement. Call Diesel Injection Service they can give you the manufacture min/max tolerances of the turbos. That is where I get all of my turbo parts. You will need the turbo ID to help them get the correct parts and specs.. PH# 616-531-1030, they are located in Wyoming MI
JEEPSTER401 is offline
post #3 of 9 (permalink) Old 08-12-2010, 02:59 PM Thread Starter
Re: Turbo rebuild
I actually called them about 20 minutes ago to get prices on a rebuild. Didnt actually get the specs. Do they know the specs for movement w/out oil in the bushing housing?
post #4 of 9 (permalink) Old 08-12-2010, 03:17 PM
Re: Turbo rebuild
I am not sure how you are taking your measurements but these are the specs
LP turbo axial endplay max .008"
radial shaft movement max .035"
HP turbo axial endplay max .008"
I think that your LP may have excessive axial movement but not to bad. I would just get the rebuild kit and do it yourself.
post #5 of 9 (permalink) Old 08-12-2010, 03:56 PM Thread Starter
Re: Turbo rebuild
I actually didnt take the meausurements. The tech at ford did then they denied my warranty.
I will probably do that. Any special tricks when rebuilding? special tools?
post #6 of 9 (permalink) Old 08-12-2010, 04:51 PM
Re: Turbo rebuild
Typically they are not to bad to do. As far as special tools there are non out of the ordinary that you should need.
post #7 of 9 (permalink) Old 08-12-2010, 06:39 PM Thread Starter
Re: Turbo rebuild
Awesome. Thanks a lot. Ryan
post #8 of 9 (permalink) Old 08-12-2010, 08:06 PM
WWDD
Dzchey21's Avatar
Re: Turbo rebuild
Good thread...
couple trucks one fast one not
Dzchey21 is offline
post #9 of 9 (permalink) Old 08-13-2010, 01:03 PM
Re: Turbo rebuild
Let me know if you need any more specs on them. I should have all of them, it would just take a little digging.
You may not post new threads
You may not post replies
