6.4 acting weird. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 01-23-2017, 12:28 AM Thread Starter
6.4 acting weird.
So I bought this 6.4, throwing a inj 8 code right off threw a new ford oem one in deleted the truck and now randomly at idle stumbles regaurdless of temp cold warm whenever it wants. Shut the truck off and it's fine 100%, has great power wouldn't know there's an issue, also sometimes it throws raw white fuel at idle and when stepping on it. I have a weak low pressure pump which is getting fix (maybe causing the inj 8 code). Now only thing I haven't done was put egr block plates. Need info scared it could be a piston problem but when it's not acting up it runs like a top.
Zhaff is offline
post #2 of 2 (permalink) Old 01-23-2017, 12:56 AM
wackyman9's Avatar
Re: 6.4 acting weird.
How's your coolant level?
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
You may not post new threads
You may not post replies
