Up pipes - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 03-23-2019, 04:16 AM Thread Starter
Jesse Malaer's Avatar
Up pipes
Is there a way to replace the up pipes without raising the cab I’m fixing to do a egr delete and replace up pipes so any help would be appreciated
Jesse Malaer is offline
post #2 of 11 (permalink) Old 04-15-2019, 07:55 AM
TooManyTrucks's Avatar
Are you install oem up pipes or upgraded? If you are installing upgraded pipes WITHOUT the EGR branch they slide in fairly easily cab on from underneath/through the wheel well. I always remove both wheel wells and spray the #### out of the bolts. The top bolts I access with a long ratcheting box wrench from the driver side behind the turbos (you need to get skinny and your arms will get torn up!) the lowers are accessed through wheel well/underneath with a 1/4” ratchet and socket, swivel sockets do a world of help. The oem up pipes, to remove them I use a sawzall to cut off the egr branch and slide them out. It’s pretty cut and dry, biggest bitch is the top bolts but I’ve done about 30 trucks this way and takes me about an hour for complete replacement.. the first go at it took about 6 hours in all honest to figure out my best method. Good luck and RIP arms/knuckles!
Mr_Andy likes this.
TooManyTrucks is offline
post #3 of 11 (permalink) Old 04-15-2019, 07:56 AM
Might I add, I’ve done all this with the trans in, however removing the trans would make it a hell of a lot easier. Just food for thought but I’m lazy so I never took the time to drop the transmission.
post #4 of 11 (permalink) Old 04-20-2019, 07:30 PM
jsandoval173's Avatar
I might need to do this also so what aftermarket up pipe would you recommend? Thanks
jsandoval173 is offline
post #5 of 11 (permalink) Old 04-21-2019, 03:33 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Up pipes
AFE makes some. Flo-Pro does as well. BD makes a whole up pipe kit with upgraded 6.0 high flow exhaust manifolds too.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 5.8L XLT Tan leather interior. Soon to be swapped onto a 6.0 frame.
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #6 of 11 (permalink) Old 04-22-2019, 08:25 PM
Ahab's white whale
brc68's Avatar
Re: Up pipes
I'm just completed a turbo back exhaust and up-pipe replacement. In fact I'm putting the tires on tonight. I raised the cab 6" to remove the down pipe. You may be able to remove the up pipes with a sawzall. It's gonna be tight threading the new pipes into the correct location. At a minimum, whether you raise the cab or not, you will need a 1/2" drive 24" flex head ratchet with a quality 10mm deep set socket. I suggest an impact socket. These two items will be required to remove the up pipe to turbo flange connection bolts. Use the hell outta Youtube, before you get started. There are several great videos for this swap out.
I shoulda been a cowboy. . .
2008 White Ford F350 Crew Cab, long bed, dually, 4WD, 5" Flo-Pro turbo back, GPP 6.0L exhaust manifolds, hi-flow up pipes, Patriot Command Center 275, w/tweaks, S&B cold air intake.
brc68 is offline
post #7 of 11 (permalink) Old 04-25-2019, 08:09 PM
Thanks guys just getting my delete kit together and do my up pipes after... Or might wait another month and do my up pipes before i delete... Thanks again fellas
post #8 of 11 (permalink) Old 04-26-2019, 05:37 PM
Luddite in Charge
Mr_Andy's Avatar
Re: Up pipes
If you don't need the truck on a daily basis just nail it all at once.
Mr_Andy is offline
post #9 of 11 (permalink) Old 05-02-2019, 03:27 AM
Thanks andy its my daily driver to work....so i might jus keep my delete in the package til i have enough funds for the up pipe too... Lol man cant wait
post #10 of 11 (permalink) Old 05-02-2019, 11:55 AM
Luddite in Charge
Mr_Andy's Avatar
Re: Up pipes
Figure on some time then for those up pipes. You can finesse them in cab on but it ain't gonna go smooth or quick. Old ones out with two cuts from a sawzall. New ones in with a lot of beer and patience. Hope you've got a few swivels for your ratchet extensions. Passenger side worse than drivers side.
Doing that job cab on is why they make Valium
Mr_Andy is offline
Similar Threads
HD Up pipes or 6.0 Manifolds and Custom up pipes? 08BIGRIG 6.4L Power Stroke - Aftermarket & Performance 13 03-31-2012 04:37 AM
DIY up pipes Shaw 1994-1997 OBS Power Stroke - Aftermarket & Performance 5 08-09-2007 09:08 PM
up-pipes dag 7.3L Power Stroke - Aftermarket & Performance 26 08-08-2007 07:35 PM
