Scary exhaust backpressure readings! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-11-2019, 07:04 PM Thread Starter
This is complicated so I'll keep it simple to start and let people who know more than me ask what they need. My exhaust back pressure has normal readings at idle (like 13psi) but elevates very quickly when accelerating or even in park while revving. If I Rev it hard at all it will max out my guage (170+psi). Here's the kicker.... Same readings when disconnected from the engine but still plugged in.... Same reading with a different sensor as well. Also, my desired backpressure is elevated to the same levels. Manifold absolute pressure reads 13 - 14 at idle but bounces around between that and around 20 under load. Ask me anything else you need to give you an idea. Thank you so much in advance for taking the time to help!
Kyle Jennings Robinson is offline
post #2 of 2 (permalink) Old 11-20-2019, 06:32 PM
TD-5's Avatar
Re: Scary exhaust backpressure readings!
What are you reading these numbers from, an actual gauge or from a digital read out from a tuner or monitor?
2010 F350 KR CCLB, mini max, ARP studs and more
TD-5 is offline
