2010 f450 with high frequency of regen cycles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-11-2019, 12:48 PM Thread Starter
im helping to get this truck running good again, buddy had a hpfp p0088 code that didnt recover from reflash for that code, intermittantly going into limp mode, after pump replacement, its trying to regen every startup, he did replace dpf less than a year ago, and since we pulled and cleaned it, besides dpf pressure sensor, are there any other sensor values suspect for causing regen cycling? im sure we have to remove and re-clean dpf again, im hoping someone has seen a similar situation that might lead to a conclusion to this problem.
dieseling is offline
post #2 of 14 (permalink) Old 07-11-2019, 01:17 PM Thread Starter
Re: 2010 f450 with high frequency of regen cycles
and it had p246c dpf pressure code
post #3 of 14 (permalink) Old 07-11-2019, 01:31 PM
Master BS'er
jamiesaun's Avatar
I don't believe there are any other relevant sensors, but I'm not positive on that.
In any event, I think you're on the right track. Check the sensor values closely. The rear one in particular.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is online now
post #4 of 14 (permalink) Old 07-11-2019, 01:36 PM
Master BS'er
jamiesaun's Avatar
In thinking about this a bit more, if the filter were clogged, I suppose there would be a temperature difference too. I still think the pressure sensors would have the final say, but check the temp sensor values too. Just for the hell of it.
Brother James
post #5 of 14 (permalink) Old 07-11-2019, 01:56 PM Thread Starter
these temp sensors primarily monitor regen extreme temps?
post #6 of 14 (permalink) Old 07-11-2019, 04:36 PM
Master BS'er
jamiesaun's Avatar
They just monitor the exhaust gas, at all times. It is primarily for Regen purposes, but yeah, they're always running.
Pretty sure it's gonna be either a sensor issue or the dpf really is clogged. You gotta figure out which it is.
Brother James
post #7 of 14 (permalink) Old 07-13-2019, 01:03 PM
Luddite in Charge
Mr_Andy's Avatar
Why not just delete it and be done?
Mr_Andy is offline
post #8 of 14 (permalink) Old 07-13-2019, 01:25 PM Thread Starter
i would love to delete it, california dosent require emmissions test on rural high gvw vehicles, only way i might get away with it, is gut it and run tuner deleting dpf monitors. at least it would pass visual inspections, roadside inspectors are now going after loud or modified exhaust cars and trucks, they make you pull up on a ramp trailer, for underside visual inspection, ive seen 5-6 cars in line they have pulled over waiting their fate, anything beyond oem is illegal, their really going after the modded compact cars, myself, i dont own anything legal, but trucks are not the focus, mine are all exempt.
post #9 of 14 (permalink) Old 07-13-2019, 03:05 PM
Master BS'er
jamiesaun's Avatar
For now. I imagine they won't be exempt for long.
Brother James
post #10 of 14 (permalink) Old 07-13-2019, 03:29 PM
Luddite in Charge
Mr_Andy's Avatar
If they ever bring emissions laws to Pennsy I'm definitely fukced. None of my pickups have anything more than straight pipes and the EGR garbage is rusting in the woods with bullet holes in them.
I really want to take the Sawzall (DeWalt, of course) to my tri-axle and let it breathe properly but DOT occasionally hits me in it so I can't.
Mr_Andy is offline
