09 rear dust shield / backing plate - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 (permalink) Old 06-23-2019, 02:39 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Does anyone know of a kit with everything to replace the dust/splash shield on a SRW 350?
I've been putting together a list, separately I've got the backing plate, e-brake shoes, hardware kit, hub seal, axle seal, umm.... what am I missing.... well, that's why I'm asking if ABC Auto or someone on fleabay threw together everything in one deal.
Ford realized their dumb design and offer a plug n play backing plate with new e-brakes and hardware for $400 but that's all OEM prices and it's only the backing plate and e-brake, I want it all.
Maybe I should rip it apart and see if I need bearings too, why not make this as costly a repair as possible. Hmph
Mr_Andy is offline
post #2 of 11 (permalink) Old 06-23-2019, 06:44 PM
matthewd11's Avatar
The ford one comes with the shoes , hardware, levers, dust shield everything already pre adjusted with the caliper anchor bracket. All else you’d need to buy is the wheel seal and the axle o ring if so desired but I have reused them without issue.
The bearings last a very long time and only usually fail from lack of lubricaion,improper adjustment or if you have HUGE miles
matthewd11 is offline
post #3 of 11 (permalink) Old 06-23-2019, 08:51 PM
Administrator
Zmann's Avatar
Re: 09 rear dust shield / backing plate
agreed on the bearings not being an issue
IMO most common cause for bearing failure on the sterling is when the oil slinger fails and wipes out the seal and it is apparent pretty quick
Dustybumpers likes this.
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 11 (permalink) Old 06-23-2019, 11:10 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
I'm looking at around $40 for the backing plates, $40's for Wagner shoes, $30 for the hardware, and about
$20 for Timken seals and $40 for Timken bearings and races if I decide to go all in while I have it apart. Why not, right? These prices reflect doing both sides.
Ford can keep their $400 per side junk.
The backing plate has me a little cornfused tho, the king of junk, Dorman, lists a ceramic coated plate for close to $150 whereas everyone else is in the $30-$60 range. I've always intentionally ignored anything with that name on it because they're..... what they are. But I wonder how durable something like that would be, I mean it's just a piece of steel - nothing moves or carries electricity... it serves no purpose other than to stay there and rot while holding the brake hardware together. Hard to convince myself I might want to change my opinion of Dorman but if anyone has experience with them, please enlighten me.
Mr_Andy is offline
post #5 of 11 (permalink) Old 06-24-2019, 12:07 AM
Administrator
Zmann's Avatar
Stick with your gut Dorman always seems to find a way to screw up a part and never get around to fixing the product
to bad stainless is not an option
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 11 (permalink) Old 06-24-2019, 12:11 AM
Administrator
Zmann's Avatar
I would get new oil slingers and of course you already have the special socket
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 11 (permalink) Old 06-24-2019, 02:06 AM
matthewd11's Avatar
Ahh that’s right you have something else you’re putting money aside for 😆
As far as the dorman backing plates...I have used them before and my truck needs the while cabutle that your doing but I have been procrastinating. They should last a few years at least anyway. When I do then I’ll probably put Dormans on mine. The ford units are definitely expensive
Mr_Andy likes this.
post #8 of 11 (permalink) Old 06-24-2019, 02:17 AM
Master BS'er
jamiesaun's Avatar
I use dorman products all the time.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #9 of 11 (permalink) Old 06-24-2019, 02:50 AM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Nothing is higher quality than Dorman valve cover gaskets/harnesses for the 7.3 and *any* sensor they make. Top flight all the way. :lol:
About 10 miles from here is a Dorman..... I guess warehouse, I don't think they actually make anything do they? Anyway ( @wackyman9 ) it's in Colmar if you've ever been all the way up County Line Rd right before you hit 309 and is the size of about three super WallyWorld's.
wackyman9 likes this.
Mr_Andy is offline
post #10 of 11 (permalink) Old 06-24-2019, 04:30 AM
Administrator
Zmann's Avatar
2 off the top of my head that ere huge fails
Dorman cam phasers cost many folks their ford motors
Dorman 6.0 oil coolers and the gaskets that went to goo cost plenty of folks a redo
and the sad thing is it takes them forever to fix the issues
DTR's Donation page
RIP DTR Ron
Zmann is offline
