6.4 liter diesel 2008 model has a bad lifter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-23-2019, 04:57 PM Thread Starter
could a bad lifter cause air in the fuel system today when changing my hi pressure fuel pump in top of engine I found what looked like a broken lifter..the truck would start up a run but stall after about 20 minutes then it would have air in fuel system..bleed air off system it would start run an the stall again after 20 or 30 minutes can a lifter because lower fuel pressure at the injector rail an keep causing to have air or is my bad as well...I done changed all the fuel lines an fuel pumps even replace pick up in the tank an all new injectors an tubes any help would be a blessing thank u guy for any in put
Chris Prevatte is offline
post #2 of 3 (permalink) Old 05-23-2019, 05:03 PM
matthewd11's Avatar
A lifter has nothing to do with the fuel system. You have 2 separate problems.
matthewd11 is offline
post #3 of 3 (permalink) Old 05-23-2019, 10:37 PM
sooty
Re: 6.4 liter diesel 2008 model has a bad lifter
What are you calling a lifter?
sooty is offline
Similar Threads
2008 6.4 liter runnes an stalls do to air Chris Prevatte 6.4L Power Stroke - Technical Info 4 05-09-2019 08:03 PM
2008 6.4 liter runnes an stalls do to air Chris Prevatte 6.4L Power Stroke - Technical Info 0 05-06-2019 11:04 PM
2008 6.4 liter f350 Lprevatt4 6.4L Power Stroke - Technical Info 2 03-23-2019 05:45 PM
Bad lifter???? channingt 7.3L Power Stroke Technical Info 9 06-17-2015 12:34 AM
Has Anyone Put new model seats in obs strokin w/ alil cayenne 1994-1997 OBS Power Stroke - Aftermarket & Performance 2 04-16-2009 05:14 AM
