oil leaks - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-14-2019, 07:23 PM Thread Starter
oil leaks
started noticing some oil drips on my driveway a few days ago and happened to take a look underneath my truck and found this on the driver side, any ideas of whats going on here? thanks in advance!
fifty50 is offline
post #2 of 3 (permalink) Old 05-16-2019, 11:13 AM
Luddite in Charge
Mr_Andy's Avatar
Re: oil leaks
Oil or trans fluid? The cooler lines go in the radiator right about there.
Mr_Andy is offline
post #3 of 3 (permalink) Old 05-17-2019, 03:20 PM
TD-5's Avatar
Re: oil leaks
Looks like condensed oil vapor in your hot pipe/ inlet to intercooler. Crankcase vapors are drawn in & thru turbos, the majority of the heavy oil vapor condenses at the inlet to the cooler.
2010 F350 KR CCLB, mini max, ARP studs and more
TD-5 is offline
Similar Threads
leaks leaks leaks Powerstrokin444 6.9 - 7.3L IDI Diesels 83-93 Model Years 5 05-28-2009 12:26 PM
Front seal and valve cover oil leaks........ 64pcode 7.3L Power Stroke Technical Info 6 03-23-2008 07:07 AM
damn oil leaks!!! JAKE 1994-1997 Power Stroke Technical Info 5 02-26-2008 10:52 PM
Oil Leaks Reubine 1994-1997 Power Stroke Technical Info 15 02-19-2008 09:49 PM
Oil (leaks) on a 01 F350 Cat_Rebel 7.3L Power Stroke Technical Info 6 09-13-2007 01:02 AM
