08 6.4 Transmission issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-16-2019, 03:42 AM Thread Starter
I have an 08 F-350 6.4 deleted with a SCT Livewire TS+ tuner. About a week ago i was getting a rough shift from gears 2 to 3. Along with the codes P0760 (shift solenoid C) and P0763 (shift solenoid C electrical). I went through and tested the ohms of all the solenoids and they all came tested within range. I also could not see any obvious damage to the harness. i ended up replacing solenoid C and the truck ran well for a day or 2 with no sighs of an issue. Then while accelerating from a stop light the rough shifting came back and the truck is throwing the same codes. Sense its the same symptoms and codes Im not sure where to start this time. Any suggestions?
Chodge03 is offline
post #2 of 8 (permalink) Old 04-16-2019, 03:44 AM
matthewd11's Avatar
You probably have an issue with the intermediate clutch or intetmediate piston.
Was there any metal in the pan when you had it off?
Where are you located? I do transmission work if it comes to that and if you’re interested shoot me a PM
matthewd11 is offline
post #3 of 8 (permalink) Old 04-16-2019, 03:45 AM Thread Starter
Re: 08 6.4 Transmission issue
Located near Chicago.
Chodge03 is offline
post #4 of 8 (permalink) Old 04-16-2019, 03:48 AM
matthewd11's Avatar
Ok. Was there any metal in the pan when you had it off?
post #5 of 8 (permalink) Old 04-16-2019, 03:53 AM Thread Starter
No metal in the pan or on the magnet. The truck does get used for snow plowing also.
Chodge03 is offline
post #6 of 8 (permalink) Old 04-16-2019, 03:55 AM
matthewd11's Avatar
You can load test the wires from the TCM under the drivers floorboard under the truck to the TCM harness for the intermediate clutch solenoid. If they can carry current then your issue is likey mechanical.
I’ll send you a PM
post #7 of 8 (permalink) Old 04-16-2019, 04:01 AM
matthewd11's Avatar
Pm sent
post #8 of 8 (permalink) Old 04-22-2019, 10:42 PM
Luddite in Charge
Mr_Andy's Avatar
Learn how to "feather" the go pedal, not just hammer down. I have a Suncoast and one by Brian's and both will slam shift with every tune (two 6.4's, ten tunes) if I just mash the pedal down.
Mr_Andy is offline
Similar Threads
Transmission upgrades? Transmission slipping? joshk 7.3L Power Stroke - Aftermarket & Performance 15 09-03-2011 10:39 PM
Mercon transmission fluid manual transmission? BIG_RED 1994-1997 Power Stroke Technical Info 25 04-28-2011 12:28 AM
Strange fueling issue or transmission issue????? NEVRNF Engine & Transmission Conversion 14 09-21-2009 07:05 PM
