really need information fast on my 6.4 L - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-11-2019, 12:20 PM Thread Starter
BlueChief250's Avatar
I need info on my 6.4L . My engine oil temperature shoots up to exactly 255 after a short amount of driving and stays exactly there. My mechanic says this is fine but Iíve done some research and I think I need to bring that down 😟 Now, I use an edge programmer to check my egtís, eotís and what not. Is it limited to 255 degrees and my oil is actually getting much hotter? Is my oil thermostat just going out and my temperature is actually fine? Thereís no codes 🏽 Do I flush the radiator? The oil cooler? Replace something or another? I DONT KNOW THESE THINGS. If itís not just the thermostat messing up, how do I get that oil temperature down??? 175,xxx miles. Any information is appreciated thank you!!
File Type: jpeg 15284837-354C-4135-AB60-A232F88B25D8_1554985203039.jpeg (315.8 KB, 32 views)
BlueChief250 is offline
post #2 of 5 (permalink) Old 04-11-2019, 12:33 PM
Weatherlite's Avatar
Garage
Re: DONT BAN ME i just really need information fast
I don't know much about the 6.4, but one thing which is a constant among many vehicles in this kind of situation is to check the EOT and ECT when the engine has been sitting for a good ten hours and compare them. They both should be about the same as ambient temp, and should be within a couple degrees of each other. If your EOT is reading 20 degrees high right from the start, it's going to be high the whole way through.
So, if it's way off when cold, I'd replace it and see what temps you get after that. If it's within tolerances, I'd imagine you have a serious oil cooler issue....but again, I don't know much about the 6.4, so there could be something else I don't know about.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 5 (permalink) Old 04-11-2019, 01:12 PM
Moderator
Sbluke55's Avatar
I locked all your other threads. Only 1 thread for the subject please.
Look at bullet proof diesel's half kit. Sounds like the oil cooler is clogged. But like said above check the sensors first.
01 f-250, Standard
Sbluke55 is offline
post #4 of 5 (permalink) Old 04-23-2019, 05:00 PM
Luddite in Charge
Mr_Andy's Avatar
Under 'average' driving conditions in the summertime both my 6.4's run a c-hair over 200, winter about 185-190...
If that helps.
Mr_Andy is offline
post #5 of 5 (permalink) Old 04-23-2019, 07:09 PM
alleged moderator
tjctransport's Avatar
Re: really need information fast on my 6.4 L
changed title, and moved to proper forum.
tom
tjctransport is online now
Similar Threads
I might trade for an idi. I could really use some general information plz. strokinfarmtruck 6.9 - 7.3L IDI Diesels 83-93 Model Years 13 02-10-2014 05:56 PM
when cruse control dont work, TC dont lock up????????????????? TED7.3 1994-1997 Power Stroke Technical Info 7 03-16-2013 10:37 PM
