intermitent stall a few seconds after startup - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 03-19-2019, 11:31 PM Thread Starter
I'm new to powerstrokes I have a 2008 F-350 6.4 lariat with an h&S minimaxx tuner, 4in exhaust, DPF delete, I'm not sure about the EGR delete because I bought the truck with these mods already installed but with the amount of other work done to the truck I would imagine that it has been deleted or blocked, I checked the DTC codes and found a brake switch circuit B P0703 I belive was the DTC code, the truck runs fantastic but sometimes when I start the truck it will stall a few seconds after starting, it doesn't always stall and it doesn't matter whether the truck is warm, cold or at operating temp, or plugged in, it has never stalled while driving either. I'm flippin baffled by this anyone have any ideas?
matt6487 is offline
Similar Threads
97 f250 hd 7.3. 415k truck starts & few seconds later cel comes on& runs ruogh Jordan brooks 1994-1997 Power Stroke Technical Info 12 08-13-2017 05:55 AM
Idle drops to 500 rpms for a few seconds Powerstroke` 1994-1997 Power Stroke Technical Info 8 10-10-2016 03:42 AM
07 f250 starts then shuts off after a few seconds bighoss 6.0L Power Stroke Technical Info 3 06-27-2014 04:07 PM
gray smoke for 20 seconds after startup? 2MCHPWR 7.3L Power Stroke Technical Info 3 05-26-2013 10:38 PM
04 6.0 loses power after a few seconds. bigf350sd 6.0L Power Stroke Technical Info 7 05-02-2010 10:18 PM
