P132B and P2263 - Page 6 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #51 of 56 (permalink) Old 03-10-2016, 03:30 PM
codykthekilla's Avatar
Garage
Re: P132B and P2263
Originally Posted by chandlerwest6.4 View Post
Ill go try that this afternoon, when I go to get the actuator separated from the gasket and cooler will the coolant not constantly flow out?
That is correct. The gasket really isn't a gasket, not quite sure what its purpose is, its kind of sticky though. The cooler is a closed system, only place coolant flows is into tube and out of other tube.
wackyman9 likes this.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #52 of 56 (permalink) Old 03-11-2016, 02:22 AM
wackyman9's Avatar
Re: P132B and P2263
Maybe the "gasket" acts as an anti-vibration pad or some kind of isolator? I mean it was engineered by an engineer, so it must be right lol!
Sent from my SM-G925P using Tapatalk
chandlerwest6.4 likes this.
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
post #53 of 56 (permalink) Old 03-14-2016, 01:36 AM Thread Starter
southern 6.4
chandlerwest6.4's Avatar
Garage
Re: P132B and P2263
Fixed!!!!!!!!!! p132b was 100% that actuator. I got the old one off, opened it up, and there were multiple sheared gears inside of it. So far I have learned that the p132b code is going to be directly related to the actuator and p2263 is the EBP sensor in my case.
I have noticed an issue with the truck now though.
Before I fixed this problem my truck would dump soot out of the exhaust (roll coal) but now i can't even get a puff out even if I step on it. Not that Im worried about rolling coal, but is this normal now that my turbo is working? Or is something else now the problem?
2008 6.4, 6" fabtech lift, 20x14 fuel maverick, 37x13.5 20 nitto trail grapplers, 4" AFE atlas turbo back exhaust, Sinister Diesel EGR delete with elbow, SCT livewire TS with punch it performance tunes
chandlerwest6.4 is offline
post #54 of 56 (permalink) Old 03-14-2016, 11:46 AM
wackyman9's Avatar
Re: P132B and P2263
Nope, now everything is working properly so your fuel and air combustion is efficient thus no coal train! Maybe you'll get a puff if you do a heavy acceleration, but you won't blind an intersection!
-SCT X4 Babysitter
-17" XD Addicts
-GearBoxZ DPF-R 4.0
-MPD CCV Kit
-Injen Evo CAI
post #55 of 56 (permalink) Old 03-14-2016, 12:48 PM Thread Starter
southern 6.4
Garage
Re: P132B and P2263
Awesome, didn't really care to change the color of the intersection every time I tapped the gas, thanks again for the help!!
post #56 of 56 (permalink) Old 09-28-2016, 01:25 PM
Question Re: P132B
I wonder if anyone else this this particular problem? I have a 2011 F350 with the 6.7 that I bought new. At about 15K miles it started to code the P132B and have very little turbo boost. I just removed the code, but it started to come on more often. So, I took it to the dealer and they told me it was the EGR valve. They replaced it at a cost of $1500, and it did nothing to stop the problem. Took it back, this time they said the VGT/waste gate assembly need to be replaced at a cost of $3500, and this on a truck with 20K miles. I told them that there was nothing mechanically wrong with the turbo, and the problem must be electronic. They said that their scanner said different and I was wrong. At this point I had zero confidence in their service department and said goodbye. So, I started to keep track of the situations and conditions that lead to the absence of turbo boost. HERE IS What I FOUND....Once the engine is up to temperature and I let the engine idle for as little is 10 minutes, when I resume driving, there is very little boost. As long as I shut the engine off (truck stops, fueling, ect.), no problems with max 22psi boost. The truck now has 40K miles on it, and I just finished a 2 month, 9K trip pulling a 30' 5th wheel camper with zero problems with the truck. All the power I needed and no codes. Anyone have any idea what would cause this odd behavior?
jcb52 is offline
