OEM air filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-16-2013, 12:09 AM Thread Starter
OEM air filter
My check air filter warning came on while driving in a snow storm.
Upon inspection, I found the filter and air box soaking wet.
Looked it up in a google search and see that this is a common issue.
I called the dealer and they suggested that I could dry it out. However,
I will need to replace the filter.
1. Is there something I can do to prevent my air from being conaminated with snow ant ice? I live in northern canada and anticipate more snow.
2. Is there a drop in, non-paper filter I could use as an alternative???
Thanks
Unbelievably is offline
post #2 of 10 (permalink) Old 11-16-2013, 02:38 PM
matted2thefloor's Avatar
Re: OEM air filter
Ford has a TSB out for that...
TSB
10-2-2 6.4L AIR INDUCTION SYSTEM RESTRICTION - SNOW
Publication Date: January 22, 2010
FORD: 2008-2010 F-Super Duty
This article supersedes TSB 09-6-8 to remove the production fix date, update the vehicle model year coverage and Service Procedure.
ISSUE:
Some 2008-2010 6.4L F-Super Duty vehicles may experience a lack of power during acceleration and perhaps the illumination of the check air filter message in instrument cluster message center. The lack of power condition may occur when the air filter element becomes packed with snow, thereby restricting required air flow to the engine.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Provide a winter grill cover to the customer for vehicles not equipped with one.
Replace the indicator assembly (air filter minder) if it doesn't have engineering number 8C34-9N622-AB on the part.
Remove auxiliary snow tube. (Figure 1 - Item 1)
Figure 1 - Article 10-2-2
Remove the airbox filter cover. (Figure 1 - Item 2)
Replace the air cleaner element only if wet or frozen.
Attach the snow deflector gasket. Ensure gasket is secured mainly to top of filter and then simply rests on edge of airbox. (Figure 2)
Figure 2 - Article 10-2-2
NOTE: THE DEFLECTOR GASKET MUST BE USED IN CONJUNCTION WITH THE WINTER GRILL COVER TO MINIMIZE SHOW INGESTION.
Install airbox cover.
Install auxiliary snow tube fully to the white indicator mark.
Verify the plastic breather box on the end of auxiliary snow tube does not contact turbocharger heat shields. Auxiliary snow tube push-pin to cowl must be reinstalled to prevent this.
NOTE: THE WINTER GRILL COVER MUST BE REMOVED WHEN TEMPERATURES ARE GREATER THAN 50 F (10 C) (32 F (0 C) WHEN TOWING) OR ENGINE DAMAGE CAN RESULT. THE SNOW DEFLECTOR GASKET CAN REMAIN INSTALLED IN THE VEHICLE YEAR-ROUND.
NOTE: IF YOUR VEHICLE IS OPERATED IN A HEAVY SNOW STORM OR BLOWING SNOW CONDITIONS, THE ENGINE AIR INDUCTION MAY BECOME PARTIALLY CLOGGED WITH SNOW AND/OR ICE. IF THIS OCCURS, THE ENGINE MAY EXPERIENCE A SIGNIFICANT REDUCTION IN POWER OUTPUT. AT THE EARLIEST OPPORTUNITY, CLEAR ALL THE SNOW AND/OR ICE AWAY FROM INSIDE THE AIR FILTER ASSEMBLY. TAKE THE TOP OFF THE ASSEMBLY, LEAVING THE AIR FILTER IN, AND REMOVE ANY SNOW OR ICE.
PART NUMBER PART NAME
8C3Z-19A414-A Winter Grill Cover
8C3Z-9N622-A Indicator Assembly - Filter Minder
7C3Z-9601-B Air Cleaner Element
9C3Z-9C664-A Gasket
08 F350 J3 CCLB 4x4 Lariat
Over 200k on the ticker and living healthy with the help of some goodies!
matted2thefloor is offline
post #3 of 10 (permalink) Old 11-17-2013, 12:08 AM Thread Starter
Re: OEM air filter
What s TSB and acronym for?
How would I get this work done at the dealer?
The only thing they told me was that I need a
New air filter.
post #4 of 10 (permalink) Old 11-17-2013, 12:42 AM
spence_08's Avatar
Re: OEM air filter
tecnical service bulletin go there and tell them you have a tsb for your truck and give them the tsb number and tell them to look it up most dealers that dont work on many of these trucks wont know a dam thing about it or even look for you so tell them about it and make them look it up or print it off and bring it to them
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
post #5 of 10 (permalink) Old 11-18-2013, 10:08 AM Thread Starter
Re: OEM air filter
Thanks for the help guys.
I'll be at the dealership tomorrow.
Should I be asking the for a replacement filter,
OR should I be demanding a replacement filter.
post #6 of 10 (permalink) Old 11-19-2013, 12:58 PM
Re: OEM air filter
If your turck is still under warranty, and it is exhibiting this condition, which obviously it is, they should carry out the procedures in this TSB without question.
post #7 of 10 (permalink) Old 11-26-2013, 01:47 AM
spence_08's Avatar
Re: OEM air filter
how did it go with the stealer ??
post #8 of 10 (permalink) Old 11-27-2013, 05:00 AM Thread Starter
Re: OEM air filter
At the dealer, I talked to one service advisor.
He found the TSB, printed it out and told me to
Go to parts to order what they needed to do the work.
Once at the parts counter, I had to pay for the new filter.
Parts told me they would need a work order to get the work
done. Once done, I was told I would be reimbursed the cost
of the filter.
Once I booked my service appointment (different service advisor),
He suggested that I would be stuck with a retail bill if the cause
Of the check filter indicator was not a result of filter contamination
as a result of snow build up.
I go in for service next week!
post #9 of 10 (permalink) Old 12-10-2013, 03:30 AM Thread Starter
Re: OEM air filter
Brought my truck In with the idea that they would do the work.
They didn't. Said that it wold only be covered if I had existing
limited 60000km warranty, which I didn't.
They did however replace some sensors and a flash under the
Extended warranty...truck hasn't run this well in a long time.
Only wish it wasn't -25
post #10 of 10 (permalink) Old 12-11-2013, 02:51 AM
skobiak's Avatar
Re: OEM air filter
Invest in a winter front. It will help keep the snow out of the engine bay.
2008 F350 CCSB
skobiak is offline
