The Centaurus Resurrection - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 52Likes
post #11 of 85 (permalink) Old 02-14-2019, 05:24 PM
don't play well w others
Dustybumpers's Avatar
Re: The Centaurus Resurrection
The edit button shows up after 10 posts
Until then, if it's a major issue Tom, @tjctransport, or Shaun @Sbluke55 can fix it for ya
Gotta watch that Tom guy tho, no telling what he might put back in there....
Not that I would put anything bad about him anywhere on the internet
dodgetruck2 likes this.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #12 of 85 (permalink) Old 02-14-2019, 05:44 PM Thread Starter
dodgetruck2's Avatar
Garage
haha not a big issue just used to being able to edit my orginal post as things change, and i went back to modify my other post about the module instead of posting a new one and I couldnt at that point i went daheck?
1996 F350 7.3L 5spd 2wd CrewCab Dually Centaurus
TS6 BoxTuning l ISSPRO EV2 Fuel, EGT, Trans, Pyro l High Pressure Oil Crossover l BB Mod 70psi l FastCoolers w/ 9 qts Mercon V l 3"DP to 4" Dual Exhaust l EBPV Control l 33Gal Rear Tank mod l more to come.....
dodgetruck2 is offline
post #13 of 85 (permalink) Old 02-14-2019, 05:49 PM
Yeah, it changes after your here for a while
Good thing for me, with my spelling.....
masakimm and dodgetruck2 like this.
Charlie
post #14 of 85 (permalink) Old 02-14-2019, 05:51 PM
If you use tapatalk, ther is no edit button. Just a heads up there.
Charlie
post #15 of 85 (permalink) Old 02-14-2019, 05:55 PM
Moderator
Sbluke55's Avatar
So you know. You can edit on tapatalk. Just tap the post. Hit more button on the iPhone or the screwdriver and crescent wrench on the android. There will edit button in the menu.
01 f-250, Standard
Sbluke55 is offline
post #16 of 85 (permalink) Old 02-14-2019, 05:57 PM
Dam. That is good 2 know
Thanks
Sbluke55 likes this.
Charlie
post #17 of 85 (permalink) Old 02-14-2019, 09:34 PM Thread Starter
Garage
Not sure why just realized on my home laptop this comment never got posted last night, so insert this at about 730pm 2-13-19 haha
Well big shout out to riffraff diesel for the insanely fast shipping on my TS6 they beat amazon prime. My TS6 arrived and the dummy plugged i planned to use in my pillar pod but since i opted with a good deal i found on a new gauge set on facebook from someone who changed project directions i no longer have an open hole in my gauge pod as i didn't intend on getting a fuel pressure gauge at the time but now with the idea of developing an efuel setup i feel the gauge won't be such a bad idea. I'm not sure the reasoning or why its there but i have a hole in my dash next to the tank selector probably stick the TS6 in there for now.
post #18 of 85 (permalink) Old 02-14-2019, 10:02 PM
alleged moderator
tjctransport's Avatar
ya got to be careful with them fellers at RiffRaff.
they are very good at fooling into feeling good about them, while they secretly empty your wallet!
Lt.Dan, heavydoc and dodgetruck2 like this.
tom
tjctransport is offline
post #19 of 85 (permalink) Old 02-14-2019, 10:55 PM Thread Starter
Garage
Ive met a few shady people like that but when ya want to go fast ya want to go fast
post #20 of 85 (permalink) Old 02-15-2019, 11:19 AM Thread Starter
Garage
Got the TS6 installed this morning boy them running boards made hard work of removing the inner fender but we got er, She was a virgin PCM, Once you have the glue cleaned off you can essentially pull the tuner through the brake bracket access cant you? I didnt have time to mount the control knob like i had planned so its just tucked under steering wheel for now, i was in to much of a hurry and worried i might end up breaking the dash bezel. We'll get to it this week, also my fuel tank kit, ebpv controls and EV2s showed up last night played around with the programming some on those. Hopefully get to installing most of that this weekend
Similar Threads
Project Resurrection 97 F250 CCSB evans213 1994-1997 General Aftermarket 61 08-01-2013 02:03 PM
Project Resurrection BigStroker 1994-1997 General Aftermarket 142 11-17-2011 02:21 AM
6.0 resurrection SSpeeDEMONSS 6.0L Power Stroke - Aftermarket & Performance 68 04-26-2011 01:00 AM
Resurrection And Life Powerstroke Racer Politics and Religion 0 04-25-2011 02:42 PM
