Project Shamu Build - Page 110 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 261Likes
post #1091 of 1120 (permalink) Old 05-14-2019, 01:46 AM
longjonsilver's Avatar
Re: Project Shamu Build
Originally Posted by masakimm View Post
Here's what I running for filters and my setup.
I was born into Gobernment health care. And will die in Gobernment Health care. God Bless Our Military Men And Women.
Donaldson is good stuff
masakimm likes this.
longjonsilver is offline
post #1092 of 1120 (permalink) Old 05-14-2019, 01:47 AM
Native Californian
BBslider001's Avatar
Originally Posted by ​ DieselDC View Post
It’s a 7.3... doesn’t need one. 6.0 yes I recommend it (I do have one on the 6.0).
I have one for the 7.3 sitting some where. If you need it you can have it - just text me lol.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
Yup, many, many 7.3s have been run for 100s of 1000s of miles without them. My last 4 7.3s worked hard and none if them had one. I think it's a matter of "feel good" like additives. Run it if ya want to. More power, blah blah blah. I highly doubt it's gonna make or break the longevity in the long run, but they sure got our money.
Sent from my Pixel 2 XL using Tapatalk
​ DieselDC likes this.
Byron
1999 F-350, 4x4, ZF6, AFE CAI, 4" DP and Exhaust by Diamond Eye, Fuel Rail FX by RiffRaff, Cat Deleted, Cody tuned
1997 F-350 CCLB DRW, 7.3 PSD, Heavily Modded SOLD
1995 F-350 CCLB SRW, ZF 5-Speed, 4x4, Stock, SOLD
1997 F-250 SC Flatbed, ZF 5-Speed, Stock, SOLD
2010 K-Z Sportster Toyhauler 37K, Various horse and stock trailers
BBslider001 is offline
post #1093 of 1120 (permalink) Old 05-14-2019, 01:49 AM
True enough, however why not ?
post #1094 of 1120 (permalink) Old 05-14-2019, 01:55 AM
Native Texan
masakimm's Avatar
Garage
That's the way I felt. Now I was not giving a company 100's of my dollars so bought a cheap filter base. some brass fittings and the filters which i got a great deal on so into it for like 75 bucks. and have filters for a many changes.
Upgrades:
masakimm is offline
post #1095 of 1120 (permalink) Old 05-14-2019, 02:00 AM
That’s not what he said however . He said they didn’t need one because they didn’t come from the factory with it .
However , big however the DT444 has a filter on it from the factory . Ford decided to put their own waterpump on the 7.3 removing the water filter. So I’d be so bold to say they did indeed put it on them for longevity...
that’s my opinion , ymmv
post #1096 of 1120 (permalink) Old 05-14-2019, 03:09 PM
Native Californian
Why not what? Why not use one? It ain't broke....More leak points, more things to keep track of, more expense, more unnecessary crap under the hood. I haven't used one yet in the 15 years of owning 7.3s, don't plan on starting now. If it came with one, fine, but to spend my money/time on something that isn't going to make a real difference, no thanks. I have enough stuff to do ...
Byron
post #1097 of 1120 (permalink) Old 05-14-2019, 04:11 PM
I agree . My service truck doesn’t have one . My idi does
post #1098 of 1120 (permalink) Old 05-17-2019, 01:59 PM Thread Starter
Project Shamu
Lt.Dan's Avatar
Picked up the new rear axle I've been wanting. Got it off craigslist for $100. After scouring the internet for months now, I finally got a decent deal on one. Came with brakes, a VSS, parking brake cables, etc, pretty much fully assembled. Only down side was I didn't know what gearing it had, the tag broke off, and the guy didnt want to pull the cover. So I drove and picked it up last night, spent about $100 in gas getting there lol.
So i popped the cover this morning and counted ring and pinion teeth, its a 3.73 axle, with an open diff. I'm needing 4.30 gears to match my front, so I guess I'll go get it regeared.
Either way, scored.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 372,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #1099 of 1120 (permalink) Old 05-19-2019, 03:01 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Got to work on the axle today, stripped it down to inspect it, and I gotta say, I'm impressed for $100.
I started out getting it out of the back of my truck, and being by myself, I was able to just slide it over onto my workbench and get it up on stands.
Then I pulled the brakes off, found the rotors are down to nothing, and pads are trashed, rubber brake lines look pretty scary, and the caliper slide pins are seized. The passenger side parking brake is missing a lot of pieces, like the previous owner robbed some of them for something else, but the shoes are fine, so pretty much all of the brakes are getting replaced.
Then pulled the axle shafts and hubs. The bearings still look great, very clean and no pitting, they're all Timken, so I will just reuse them, but the seals came apart when I removed them, so I'll buy some new ones. Then just cleaned all the oil off of everything and set it aside for reassembly.
Continued...
SOLD
Lt.Dan is offline
post #1100 of 1120 (permalink) Old 05-19-2019, 03:02 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
More pics...
SOLD
Lt.Dan is offline
