Project Shamu Build - Page 109 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 261Likes
post #1081 of 1120 (permalink) Old 05-13-2019, 03:50 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Re: Project Shamu Build
No coolant filter. But I do want one.
You thinking it has some clogged up passageways and a coolant filter will fix this high heat problem? Or that a filter could cause problems in some way?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 372,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #1082 of 1120 (permalink) Old 05-13-2019, 04:06 AM
​ DieselDC's Avatar
It’s a 7.3... doesn’t need one. 6.0 yes I recommend it (I do have one on the 6.0).
I have one for the 7.3 sitting some where. If you need it you can have it - just text me lol.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
BBslider001 likes this.
​ DieselDC is offline
post #1083 of 1120 (permalink) Old 05-13-2019, 04:25 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Eh, I don't think its a bad idea to put one on, so long as its a bypass filter. Maybe I'll hit you up. Thanks bud.
SOLD
Lt.Dan is offline
post #1084 of 1120 (permalink) Old 05-13-2019, 05:07 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Side note... Pitman Arm, rev 2. I went down to 3/16" mild steel, so I can tig weld it without there being a massive gap to fill, I added a center rib that you can't see in the shot, and also added a jog in the center to add for clearance of the drag link when turning (mine barely touches at full lock). Its also a little longer than my old one, and much longer than the stock one. I should be able to get over 43* of steering, one way, with this pitman arm. Even though the stock axle shafts are only good to about 33-35*, with some minor trimming I can get 38* and be steering wayyy better than the 30* or less than I have now.
Now I just need to find the time. Can't wait.
SOLD
Lt.Dan is offline
post #1085 of 1120 (permalink) Old 05-13-2019, 11:04 AM
longjonsilver's Avatar
All Diesel engines should have a coolant filter . Wether or not they “need one” is opinion . A filter system is a perfect way to add SCA into the system . My thought was if there was indeed trash in the system the filter will certainly let you know .
You can install the filter in a bypass way by teeing into the heater hoses , that way if the filter should plug up there is still coolant flow .
I had a truck that plugged two filters in a short amount of time with trash . We flushed the system before we installed the filter . Surprising what is in these engines .
Whoknows likes this.
longjonsilver is offline
post #1086 of 1120 (permalink) Old 05-13-2019, 01:10 PM
HilhavenFarm's Avatar
Agree with @longjonsilver
Mine was a Christmas gift but have been pleased.
It comes with a Baldwin 5134 filter but I use a Napa 4070.
longjonsilver likes this.
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #1087 of 1120 (permalink) Old 05-13-2019, 01:37 PM
Native Texan
masakimm's Avatar
Garage
I just built my own inline with input to the heater core. Keep that heater core clean.
Explosive Diarrhea not ur friend but a great weight loss tool.
Blue-Truck-Nut97 likes this.
Upgrades:
masakimm is offline
post #1088 of 1120 (permalink) Old 05-13-2019, 02:57 PM
Blue-Truck-Nut97's Avatar
Agreed with you three. That's a mighty clean looking under hood there buddy, props to you. Have you had any trouble with that short hose between the filter/ radiator? From the picture that looks like a good place for it to pull off during a frame twister type situation, but it's a picture, so can't tell.
Blue-Truck-Nut97 is offline
post #1089 of 1120 (permalink) Old 05-13-2019, 05:55 PM
I don't dog the Blue Bomber much, so frame twisting is rare. But I have not had one issue with the set up. I also check all my hoses and connections religiously. I try to keep engine as clean as possible so no leaks do sneak up on me.
I am getting ready to change my water pump, coolant and the filter so will try to remember to take some pictures of filter and may try to cut it open for us to see.
I bounced around doing my own set up as @masakimm did, but a gift is a gift. I mentioned one time I would like to have one as they are clean looking and functional, it was my only gift that Christmas from my family.
masakimm and Blue-Truck-Nut97 like this.
1974 Deutz 5506
post #1090 of 1120 (permalink) Old 05-14-2019, 01:34 AM
Native Texan
masakimm's Avatar
Garage
Here's what I running for filters and my setup.
I was born into Gobernment health care. And will die in Gobernment Health care. God Bless Our Military Men And Women.
Upgrades:
masakimm is offline
