Not sure where to post - Body Work - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-16-2011, 01:40 AM Thread Starter
Back in Black
stroken's Avatar
Im not sure where this should be posted but I am in the middle of building my reg cab drag truck.
It needs some body work. anyone have some step by step advice on this? I mainly am looking for like sand paper grits and such. I did some bondoing, im just not sure what grit to sand it down with so it wont leave marks throughout the truck and show through the new paint. Ive searched the internet but didnt come up with much. Thanks Guys
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
post #2 of 2 (permalink) Old 04-05-2011, 08:31 PM
Re: Not sure where to post - Body Work
Hot Rod magazine had a series of articles on bodywork and painting a couple of years ago. Very good info for someone trying to learn all the issues with bodywork. You will need quite an assortment of sand paper and blocks to sand an entire vehicle. I start off with 80 grit and work my way up to 400. I keep on hand 80, 120, 240, 320, and 400. Once everything is smooth with 400 grit I apply the primer and if you have no problems after that you can continue to apply basecoat then clear coat.
2003 F250 6.0 CC LB
ARP's, Straight Pipe, IDP Tuned & FICM, Custom EGR Delete, Coolant Filter, PS Filter, Bypass Oil Filter, Upgraded Fuel Lines & Crossover, EGT & Fuel Pressure
tnadanzig is offline
