single stage urathane paint question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-29-2010, 12:21 PM Thread Starter
jaybuller's Avatar
eastwood has these one gallon kits of single stage urathane paints and clears. They are 110 dollars per gallon kit. I will be spraying my white truck because the paint is cracking up and flaking off the roof and hood. I plan on snding down all the flaking paint down to the factory primer and then spraying the paint then clear coating it. Have any of you used this kind of paint? just wandering if it is crap or if it will hold up? thank you
Jay
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 3 (permalink) Old 12-29-2010, 12:31 PM
Re: single stage urathane paint question
Never used Eastwoods brand but have used lots of PPG Concept. Out here in the AZ sun it's good for about 2-3 years then it's cooked. It's like anything. Pay cheap and weep. I try and tell everone to spend alittle more and get a good basecoat clearcoat system. After you factor in time and coverage. It's not much more and will last 3x longer.
Rodknocker is offline
post #3 of 3 (permalink) Old 01-01-2011, 03:19 AM
tnmoose's Avatar
Ya what he said. Plus sanding down to fact primer won't work either. You need to feather flaking paint by DA sanding,prime then prep for paint or old paint will ring out or some call it map edging. Spend a lil more time and $ and be happy
tnmoose is offline
