brake clean overspray? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-12-2010, 12:56 AM Thread Starter
independentreb12's Avatar
well its not so much of overspray, more of a run. i taped on covered around the badges on the fender but i had some run down when i was hitting it with brake clean. now there are some streaks that wont come off with a wash and wax. any suggestions? its not that bad, but i would like it gone.
2008 ccsb 4x4
a few things done
independentreb12 is offline
post #2 of 10 (permalink) Old 07-12-2010, 05:37 AM
police stroker's Avatar
Re: brake clean overspray?
What about acetone? I would give that a try or the meguiers scratch X good stuff takes out tree branch scuffs might pull that out. Worst case I'd try a clay bar and soultion they normally sell in the detail section at the auto parts store.
police stroker is offline
post #3 of 10 (permalink) Old 07-12-2010, 11:44 AM
bluedge8's Avatar
you've probably damaged the clear coat. i'll bet it won't be fixable w/o paint
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #4 of 10 (permalink) Old 07-12-2010, 07:19 PM
userma3648's Avatar
try to buff it out if that dont work then its messed up
08 6.4 with some goodies
userma3648 is offline
post #5 of 10 (permalink) Old 07-12-2010, 09:58 PM Thread Starter
buff it out with what?
2008 ccsb 4x4
a few things done
post #6 of 10 (permalink) Old 07-12-2010, 10:01 PM
bluedge8's Avatar
rubbing/polishing compound, this is an area I have heard about but never was good at (detailing)
bluedge8 is offline
post #7 of 10 (permalink) Old 07-13-2010, 10:50 PM
Death Row Inmate #7
strokin'_tatsch's Avatar
try a fine polishing compound. if that doesn't do it then it's going to be a more in depth fix for sure...
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
post #8 of 10 (permalink) Old 07-14-2010, 12:36 AM
userma3648's Avatar
buff with adams swirl and haze and adams fine machine
post #9 of 10 (permalink) Old 07-19-2010, 07:37 PM
You have surface damaged the clear coat , you need to buff it with rubbing compound it is an abrasive. You could "TRY" a clay bar , but im sure its deeper then a clay bar will reach. I dont know about the adams stuff but its a swirl mark and haze remover so its a semi abrasive product. I personally would use 3M perfect it II fine cut. and finish with a polish of your choice.
Donnief is offline
post #10 of 10 (permalink) Old 07-25-2010, 10:55 PM
00Rich's Avatar
wd-40
2008 F-250 FX4 cc,4x4
00Rich is offline
